obd1 dizzy hardwire to ecu
Old Jul 25, 2013 | 02:37 PM
88_hatch_ls's Avatar
Default obd1 dizzy hardwire to ecu
Like the title states I just need to hardwire my obd1 dizzy directly to the ecu. If anyone can tell me what ecu pin numbers go to wich color wire from the dizzy that would be great. I've searched all over but cant find what im looking for and I need help asap!
Old Jul 25, 2013 | 03:30 PM
swordofdoom's Avatar
Default Re: obd1 dizzy hardwire to ecu
To what OBD wire harness?
Old Jul 25, 2013 | 03:53 PM
a p28 ecu. harness doesnt matter at this point im wiring directly from the ecu to the dizzy
Old Jul 25, 2013 | 03:54 PM
F22Master's Avatar
http://lmgtfy.com/?q=obd1+ecu+pinout&l=1
Old Jul 27, 2013 | 08:31 AM
jdmjunkieXL's Avatar
There is a pinout online of all honda dizzy obd0-obd2ab all on one image with wire colors and everything search fir it but wut u mean harness dosnt matter?? All the wires from obd0-obd1 dizzy should match right up except one i think for ign + but not really sure and thats if your using a jumper
Old Jul 27, 2013 | 09:27 AM
Sorry to clarify i thought he was talking about jumper harness from Ecu that's what I was saying didn't matter, if you mean engine harness its my stock dpfi harness.
Old Jul 27, 2013 | 02:16 PM
89-efcivic-si's Avatar
Not to sound stupid or anything kinda new to Honda and even newer to the forum what is this dizzy thing I keep seeing posted? Slang?
Old Jul 27, 2013 | 02:42 PM
It means distributor
Old Jul 27, 2013 | 04:40 PM
I thought so but I wasn't sure lol
Old Jul 28, 2013 | 01:46 AM
If you plan to wire it directly make sure you use a cable that has a built in shield so you can ground it out. You be amazed how much problems it causes if your just using straight wire to wire connections.
Old Jul 28, 2013 | 08:40 AM
The only wires I ran were the two your supposed to when you do the dpfi-mpfi swap. It's just that now the problem is that when i use my volt/ohm meter on the dizzy plug there are three wires that show ohms to eachother only when the ecu is plugged in like they touch somewhere in the ecu..b11,b12, and b14 all ohm out to each other. So idk if they are supposed to and I was thinking that could be the issue, a faulty Ecu
leemurrr
Aug 9, 2018 09:03 PM
88_hatch_ls
56
Sep 18, 2013 01:51 PM
Matt91
May 1, 2010 02:48 PM
my_hidden_romance
Feb 8, 2009 11:53 PM
si0385.
Dec 30, 2005 07:14 PM
