Can a Type-R gearbox fit onto B20B block?
Old Oct 24, 2002 | 08:29 PM
DC2#309's Avatar
New User
Default Can a Type-R gearbox fit onto B20B block?
as topic said, also what drive shaft should I use if I need to hybrid the engine into Civic EK?
The more info the better, tried did a search, but there is no spot on answers.
Old Oct 24, 2002 | 08:35 PM
IS3Fifty's Avatar
Default Re: Can a Type-R gearbox fit onto B20B block? (DC2#309)
i see no reason why not..... with some modification you can fit that tranny on there. i dont know how you would do, other than having the get the block spun with new holes, if the r tranny doesnt match. go with a type r drive shaft strongest you can get for your ride.
Old Oct 24, 2002 | 09:00 PM
DC2#309's Avatar
New User
Default Re: Can a Type-R gearbox fit onto B20B block? (purek9hybrid)
so which part of the gearbox should i modify, the mounting point?
Also, if I decide to get B18C-R engine, can I still use ITR driveshaft too?
Old Oct 24, 2002 | 09:05 PM
fowler!'s Avatar
There is no modification. The transmission will bolt right on. The axles will work fine (as long as they are 94+).
Old Oct 24, 2002 | 11:21 PM
tinkerbell's Avatar
Default Re: Can a Type-R gearbox fit onto B20B block? (fowler)
*shakes head* trial users...
plus will be an awesome set-up, are you going to use a VTEC head?
Old Oct 25, 2002 | 01:20 AM
Kamin's Avatar
Default Re: Can a Type-R gearbox fit onto B20B block? (tinkerbell)
and they wonder why we are so damn mean to them
Old Oct 25, 2002 | 04:59 AM
twitchm80's Avatar
AARRGG. don't speak when you don't know the correct answer, this forum is for helping others with CORRECT info. so don't answer if you don't know for sure
dinkers
Aug 11, 2013 04:04 AM
eklum
May 18, 2010 11:36 PM
LaminaRX
Jun 15, 2005 07:01 PM
aznpreludeSH
Feb 4, 2005 05:24 AM
connvict
Nov 3, 2004 11:38 AM
