Jdm H22a intake manny
so i went recently to get my civic barred , and i got some feed back from the reff i gues i have to get a AIR BOOST VALVE ? and a IAB Solinoid . i guess the jdm motors and mannys never came with a airboost valve they have a block off plate. so does anybody know if the f22's have these parts and if so can i use them ? cause these h22's are rare to find in the junkyards and retail stores dont carry them.
The boost valve should be on the end of the plenum. You will need the black box should be the same as the Accords and the solenoid you will need to run all vacuum lines properly and wire it up. You will also need to have all EGR parts to get that to work properly
holmesnmanny
Dec 14, 2010 03:21 PM
1991civicd16z6
Northern California (Sales)
Sep 17, 2008 04:09 PM
