93 Engine differences between EX and LX, ECU change?
Old Oct 24, 2002 | 08:12 PM
Dark101Knight's Avatar
Default 93 Engine differences between EX and LX, ECU change?
Well I have a 93 Accord 10th Anniversay which is pretty much an LX with more features. Anyways, I was wondering if there was any way to unlock the extra 15hp from the engine since they capped it on the LX versions and down for 125hp opposed to the EX's 140hp. ECU change? or something? Any help would be appreciated...and if I have to engine swap, might as well go with the H22A as many of you have done. Btw, hi, new to the boards
Old Oct 24, 2002 | 08:18 PM
Broman78's Avatar
Default Re: 93 Engine differences between EX and LX, ECU change? (Dark101Knight)
i thought the difference was that the lx had an 4-1 header and the ex have a 4-2-1 header. lmk if i'm wrong but i think that is the only engine difference.
Old Oct 24, 2002 | 08:19 PM
Default Re: 93 Engine differences between EX and LX, ECU change? (Broman78)
Really? I guess I was told different then.......hm.
[Modified by Dark101Knight, 5:19 AM 10/25/2002]
[Modified by Dark101Knight, 5:32 AM 10/25/2002]
Old Oct 24, 2002 | 08:29 PM
allaboutaccordz's Avatar
its the 4-2-1 headers as well as a larger intake manifold with 8 ports as opposed to only 4 on the LX. EX manifolds do fit the LX and will add 15 hp like the EX has.
Old Oct 25, 2002 | 05:19 AM
Gennady's Avatar
New User
Default Re: 93 Engine differences between EX and LX, ECU change? (allaboutaccordz)
Well, sorta. Its a dual runner into manifold. Sorta like a pre-VTEC econo power adder.
Old Oct 29, 2002 | 04:23 PM
melamine's Avatar
will an aftermarket ex header (90-93) fit a 91' lx
Old Oct 29, 2002 | 05:10 PM
YodiBrodi's Avatar
Default Re: 93 Engine differences between EX and LX, ECU change? (melamine)
yes it does
Old Oct 29, 2002 | 05:13 PM
GimpyAccord's Avatar
Default Re: 93 Engine differences between EX and LX, ECU change? (YodiBrodi)
Not trying to hijack, but why would you even replace an EX header?
I realize its ugly, but its a pretty good design.. esp when you consider whatever you replace it with will most likely just be a 1 7/8-2" collector too. (whatever is stock i forget).
Old Oct 29, 2002 | 06:13 PM
Gennady's Avatar
New User
Default Re: 93 Engine differences between EX and LX, ECU change? (GimpyAccord)
Because the stocker is so fuggin heavy, the aftermarket is prettier, and maybe a little better flowing. Plus, when its free, kinda hard to say no.
Old Oct 29, 2002 | 08:10 PM
melamine's Avatar
what is the difference between the 90-93 2.2 lx and ex models?
i know the ex has 140 hp and the lx has 125 hp, is it only the header
and exhaust ports? will i make up that difference with an aftermarket
ex header?
Old Oct 29, 2002 | 08:16 PM
KTeller8's Avatar
intakes, exhaust and header will only gain you about 10-15 total Hp max if your lucky and well dynoed and tuned. Does dont compare to the Vtec engine that the Ex has in it. Plus with the Ex you could still go with the bolt on's
Old Oct 30, 2002 | 06:14 AM
Charlie Moua's Avatar
Well I have a 93 Accord 10th Anniversay which is pretty much an LX with more features. Anyways, I was wondering if there was any way to unlock the extra 15hp from the engine since they capped it on the LX versions and down for 125hp opposed to the EX's 140hp. ECU change? or something? Any help would be appreciated...and if I have to engine swap, might as well go with the H22A as many of you have done. Btw, hi, new to the boards <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emwink.gif" BORDER="0">
dude do search..... under creator"Charlie"
I askd the EXACT SAME question like maybe 6 months ago.... it might be under the archerived files too...
Old Oct 30, 2002 | 06:19 AM
Default Re: 93 Engine differences between EX and LX, ECU change? (Wont be beat)
hey what are you guys referring to the Intake manifold?
what do you mean "8 ports?" I think i know what your taking about but it does't make any sense to me right now...
...........i'll IM wont be beat
Old Oct 30, 2002 | 06:47 AM
Default Re: 93 Engine differences between EX and LX, ECU change? (Charlie)
the EX/SE's had a dual runner intake... good for a couple ponies.
Old Oct 30, 2002 | 07:14 AM
DUAL runners & 8 ports.... WTF is that? damn please help me understand
Old Oct 30, 2002 | 07:17 AM
you know what a runner is right? its the .. tube on the intake manifold that goes to the head... F22A4 and F22A6 the car has 2 for each CYL. No head changes.. just intake manifold. if you took off the upper intake manifold plenum you'd notice 2 rows of 4 pipes (runner openings).
[Modified by GimpyAccord, 8:18 AM 10/30/2002]
Old Oct 30, 2002 | 08:39 AM
Ok that helpd out alot.. thanks man. I should be picking up my accord form the dealership somtime this late afternoon.. then i will take a look to see what i actaully have.
Old Oct 30, 2002 | 10:37 AM
gringo7718's Avatar
i have read here on HT that the lx manifold is good for top end and the ex dual runner manifold is good for low end torque. please clarify.
Old Oct 30, 2002 | 07:09 PM
Gennady's Avatar
New User
Default Re: 93 Engine differences between EX and LX, ECU change? (gringo7718)
Nothing on a Honda is good for low end torque.
T9U4ReBgO
May 4, 2008 01:45 PM
valve79
Oct 5, 2004 12:54 PM
alexcaro1
Dec 15, 2003 04:24 PM
Charlie Moua
Jun 23, 2002 09:37 AM
willyboyK20
May 10, 2002 09:02 AM
