| Image Preview (if available) | Item # | Part | Price |
 | 61959 | F BUMPER REINFORCEMENT | $95 |
 | 61961 | LH FENDER edge bent, needs fix | $65 |
| | 61963 | R DOOR,SHELL | $225 |
| | 61964 | L DOOR,SHELL | $225 |
| | 61965 | 2DR LH DOOR ACTUATOR 72150-S30-A01 | $60 |
| | 61966 | 2DR RH DOOR ACTUATOR 72110-S30-A01 | $65 |
 | 61967 | MASTER WINDOW SWITCH | $65 |
 | 61968 | LH SIDE SKIRT 71850-S30-J00ZS | $60 |
 | 61969 | RH SIDE SKIRT 71800-S30-J00ZS | $60 |
| | 61970 | L OUTSIDE HANDLE | $35 |
| | 61971 | R OUTSIDE HANDLE | $25 |
| | 61972 | GLOVE BOX blk | $45 |
 | 61973 | 2DR LH DOOR PANEL 83583-S30-A21ZA | $99 |
 | 61974 | 2DR RH DOOR PANEL 83533-S30-A21ZA | $99 |
| | 61975 | 2DR RH WINDOW REGULATOR | $75 |
| | 61976 | 2DR LH WINDOW REGREGULATOR | $75 |
 | 61977 | RH MIRROR RED 76200-S30-A22ZR | $60 |
 | 61978 | LH MIRROR RED 76250-S30-A22ZR | $60 |
| | 61979 | RH QUARTER PANEL | $150 |
| | 61980 | LH QUARTER PANEL | $150 |
| | 61981 | ROOF CUT,W/SUNROOF OPTION | $150 |
 | 61982 | RH TAIL LAMP,ON BODY 33501-S30-A01 | $90 |
 | 61983 | LH TAIL LAMP,ON BODY 33551-S30-A01 | $90 |
 | 61984 | DECK LID WITH SPOILER | $250 |
 | 61988 | REAR BUMPER COVER, few scratches | $175 |
| | 61989 | REAR REINFORCEMENT | $45 |
| | 61990 | FUEL TANK | $50 |
 | 61991 | FR/R SEAT black cloth | $75 |
 | 61992 | FR/L SEAT black cloth | $75 |
| | 61993 | REAR SEATS ASSEMBLY black cloth | $75 |
 | 61994 | STEERING COLUMN 53200-S30-A03 | $100 |
 | 61995 | DASHBOARD black | $100 |
 | 61996 | AM/FM/CD RADIO 39100-S30-A11 | $75 |
 | 61997 | DRIVER WHEEL AIRBAG BLACK | $199 |
 | 61998 | RH DASH AIRBAG BLACK | $200 |
 | 61999 | SPEEDOMETER CLUSTER,MILEAGE=147,380 | $110 |
 | 62000 | STEERING WHEEL blk 78501-S30-S92ZA | $40 |
| | 62001 | HEAD LIGHT SWITCH | $20 |
| | 62002 | WIPER SWITCH | $20 |
| | 62003 | INSIDE REAR VIEW MIRROR | $15 |
| | 62004 | RH SUN VISOR,gray | $25 |
| | 62005 | LH SUN VISOR,gray | $25 |
 | 62006 | MT IGNITION SWITCH + KEY | $115 |
| | 62007 | BACK GLASS | $85 |
| | 62008 | FR/R DOOR GLASS | $60 |
| | 62010 | RH QUARTER WINDOW GLASS, tinted | $40 |
 | 62011 | LH QUARTER WINDOW GLASS, tinted | $40 |
| | 62012 | SUN ROOF GLASS tinted | $125 |
 | 62013 | HEATER/AC CONTROL(ON DASH) | $35 |
 | 62015 | MT TRANS,MILES=147k,WARRANTY=3mo | $799 |
| | 62017 | MT JACK SHAFT | $85 |
 | 62018 | RH AXLE 44305-S30-N22 | $65 |
 | 62019 | LH AXLE 44306-S30-N22 | $65 |
 | 62020 | FRONT SUB FRAME 50250-S30-A20 | $200 |
 | 62022 | REAR SUB FRAME | $50 |
 | 62023 | FR/R UPPER ARM 51450-S30-N21 | $40 |
 | 62027 | RR/R UPPER ARM 52390-S30-003 | $45 |
 | 62028 | RR/L UPPER ARM 52400-S30-003 | $45 |
 | 62031 | FR/R STRUT N SPRING | $75 |
 | 62033 | RR/R STRUT N SPRING 52610-S30-A23 | $75 |
 | 62034 | RR/L STRUT N SPRING 52620-S30-A23 | $75 |
 | 62035 | FR/R SPINDLE KNUCKLE | $115 |
 | 62036 | FR/L SPINDLE KNUCKLE | $115 |
| | 62037 | FR/R BRAKE CALIPER 45018-SW5-003 | $30 |
| | 62038 | FR/L BRAKE CALIPER 45019-SW5-003 | $30 |
 | 62039 | RR/R BRAKE CALIPER 43018-SS0-010 | $45 |
 | 62040 | RR/L BRAKE CALIPER 43019-SS0-010 | $45 |
 | 62041 | RR/R SPINDLE KNUCKLE | $70 |
 | 62042 | RR/L SPINDLE KNUCKLE | $70 |
 | 62043 | ABS/VSA PUMP/MODULATOR | $100 |
 | 62044 | RACK AND PINION 53601-S30-A22 | $115 |
| | 62045 | POWER STEERING PUMP | $89 |
 | 62046 | ENGINE COMPUTER,MT type SH | $199 |
 | 62047 | ABS COMPUTER 39790-S30-A01 | $40 |
 | 62048 | AIRBAG COMPUTER good | $65 |
 | 62049 | ALTERNATOR 31100-P5M-013 | $55 |
 | 62050 | STARTER 31200-P5M-014 | $60 |
 | 62051 | ENGINE HARNESS,type SH 32110-P5P-A00 | $299 |
 | 62052 | DISTRIBUTOR | $79 |
 | 62053 | BLOWER MOTOR | $45 |
 | 62054 | RADIATOR FAN ASSEMBLY | $50 |
 | 62055 | AC FAN ASSEMBLY | $50 |
 | 62056 | AC CONDENSER 80110-S30-003 | $40 |
| | 62060 | POWER STEERING RESERVOIR TANK | $0 |
| | 62061 | RADIATOR OVERFLOW TANK | $20 |
 | 62062 | EXHAUST MANIFOLD type SH | $110 |
 | 62063 | INTAKE MANIFOLD | $75 |
 | 62064 | MT THROTTLE BODY type SH | $125 |
| | 62065 | FLOOR CARPET 83301-S30-A00ZA | $100 |
 | 62066 | RR/L RIM,minimal curb 42700-S30-A21 | $100 |
 | 62067 | RR/R RIM,minimal curb 42700-S30-A21 | $100 |
 | 62068 | FR/L RIM,minimal curb 42700-S30-A21 | $100 |
 | 62069 | FR/R RIM,minimal curb 42700-S30-A21 | $100 |
 | 62920 | CENTER CONSOLE, BLK, COUPLE SMALL SC | $118 |
 | 62924 | RR O2 SENSOR 36532-P5M-A02 | $100 |
 | 62925 | O2 SENSOR 36531-P5P-014 | $100 |
| | 62948 | GLOVEBOX, BLK, NICE, 77501-S30-A01ZC | $40 |
| | 62949 | IGNITION COVER, BLK | $20 |
 | 62950 | RESONATOR BOX, | $50 |
| | 62953 | RADIO BEZEL 77291-S30-G51ZA | $35 |
 | 62954 | CLOCKSPRING 77900-S84-A11 | $30 |
| | 62957 | FR/L MUDFLAP | $10 |
| | 62958 | FR/R MUDFLAP | $10 |
| | 62959 | FR STAB BAR 51300-S30-A21 | $50 |
 | 62961 | P.S. FEED HOSE 53713-S30-A22, | $100 |
 | 62962 | CENTER BEAM 50100-S30-000 | $40 |
| | 62963 | FR/R RADIUS ARM 51359-S30-N00 | $25 |
| | 62964 | RR/R MUDFLAP, | $10 |
| | 62965 | RR/L MUDFLAP, | $10 |
 | 62966 | RR ENGINE MOUNT ASSY 50810-S30-000 | $50 |
 | 62967 | FR ENGINE STOPPER 50814-SS0-000 | $40 |
 | 62968 | RUBBER TRANNY MOUNT 50805-S30-000 | $45 |
 | 62969 | ENGINE SIDE MOUNT 50820-S30-J02 | $75 |
| | 62970 | FR/L RADIUS ROD 51369-S30-N00 | $25 |
 | 62971 | FUEL PUMP UNIT 17040-S30-A50 | $40 |
| | 62975 | FR/L FENDER LINER 74151-S30-000 | $25 |
 | 62977 | MT SHIFTER CABLE, 54310-S30-305 | $185 |
| | 62985 | 57450-S30-N21, FR/R ABS SENSOR, | $50 |
| | 62986 | FR/L ABS SENSOR 57455-S30-N21 | $50 |
| | 62987 | RR/R ABS SENSOR 57470-S30-000 | $50 |
| | 62988 | RR/L ABS SENSOR 56475-S30-000 | $50 |
 | 62991 | FLYWHEEL | $100 |
 | 62993 | RR/L ABS LOWER ARM 52360-S30-900 | $40 |
 | 62994 | 52350-S30-900, RR/R ABS LOWER ARM | $40 |
| | 62999 | FUEL INJECTOR | $20 |
 | 63000 | FAST IDLE VALVE 16500-P0A-A01 | $50 |
 | 63001 | IDLE AIR CONTROL VALVE 36450-P13-004 | $125 |
 | 63042 | HEATER CORE | $45 |
 | 63110 | ARM B ASSY., RR. (LOWER) 52359-S30-0 | $25 |
 | 63111 | ARM B ASSY., RR. (LOWER) 52359-S30-0 | $25 |
 | 63112 | ATTS UNIT 41200-P6K-020 | $135 |
 | 63113 | AC EVAPERATOR | $50 |
 | 63115 | WIPER MOTOR | $50 |
 | 63119 | MUFFLER 18030-S30-980 | $100 |
 | 63121 | EX PIPE B 18220-S30-A22 (MID PIPE) | $99 |
 | 63124 | BOOSTER PUMP 46400-S30-A52 | $40 |
| 63130 | RH SYS UNIT MULTIPLEX CONTROL | $90 | |
| 63131 | CHARCOAL CANISTER 17011-S30-A30 | $80 | |
| 63132 | BRAKE MASTER CYLINDER, | $25 | |
| 63133 | 80321-S30-A02, SUCTION PIPE, | $40 | |
| 63134 | 80341-S30-A01, RECEIVER PIPE, | $30 | |
| 63135 | 80351-S30-A01 RECEIVER | $30 | |
| 63136 | 80311-S30-A01, SUCTION HOSE, | $40 | |
| 63137 | FR/R GRAY SEATBELT 04814-S30-A01ZA | $55 | |
| 63138 | FR/L GRAY SEATBELT 04818-S30-A01ZA | $75 | |
| 63139 | 30520-PT9-A02, IGNITER COIL BOX | $50 | |
| 63140 | WASHER RESEVOIR, | $40 | |
| 63141 | ENGINE FUSEBOX, 38250-S30-A02 | $100 | |
| 63147 | 80315-S30-003, DISCHARGE HOSE, | $60 | |
| 63148 | RH WIPER, 76610-S30-A01 | $15 | |
| 63149 | LH WIPER, 76600-S30-A01 | $15 | |
| 63150 | POSITIVE BATTERY CABLE 32410-S30-000 | $20 | |
| 63152 | RR/L GRAY SEATBELT, | $25 | |
| 63155 | GRAY RR/R SEAT BELT, | $25 | |
| 63156 | 38200-S30-N81, FUSE BOX ASSY, | $150 | |
| 63158 | 39400-S84-003, MAIN RELAY ASSY, | $20 | |
| 63204 | DASHBOARD WIRE HARNESS 32150-S30-A22 | $430 | |
| 63205 | PCM WIRE HARNESS 32111-S30-L32 | $200 | |
| 63208 | SRS MAIN 77961-S30-A00 | $110 | |
| 63221 | YAW RATE SENSOR 39962-s30-010 | $270 | |
| 63254 | TRANNY MOUNT BRACKET 50825-S30-000 | $25 | |
| 63269 | RR/R RADIUS ARM 52371-S30-A00 | $70 | |
| 63275 | RR/L RADIUS ARM 52372-S30-A00 | $70 | |
| 63286 | LEFT CABIN WIRE HARNESS | $115 | |
| 63288 | SLAVE CYLINDER ASSY 46930-SM4-003 | $30 | |
| 63291 | RR/L STABILIZER LINK | $15 | |
| 63292 | RR/R STABILIZER LINK | $15 | |
| 63297 | ENGINE STIFFENER 11950-P5K-000 | $60 | |
| 63298 | ALTERNATOR BRACKET 31112-P13-000 | $45 | |
| 63299 | RR ENGINE MOUNT BRACKET | $20 | |
| 63300 | FR ENGINE STOPPER BRACKET | $15 | |
| 63306 | WINDSHIELD COWL, 74200-S30-A00 | $75 | |
| 63307 | P.S. OIL COOLER, 53765-SS0-J00 | $40 | |
| 63368 | MASTER CLUTCH CYL | $25 | |
| 63494 | BYPASS CONTROL SOLENOID | $85 | |
| 63505 | REAR STABILIZER BAR 52300-S30-N21 | $45 | |
| 63515 | RIGHT CABIN/HEADLIGHT WIRE HARNESS 3 | $40 | |
| 63516 | GROUND CABLE 32600-S30-000 | $10 | |
| 63529 | AUTO CRUISE SPEED REGULATOR | $150 | |
| 63532 | DISCHARGE HOSE 80315-S30-003 | $50 | |
| 63562 | FR/R BUMPER MARKER LIGHT, | $35 | |
| 63563 | LH INSIDE HANDLE BLACK | $20 | |
| 63843 | THROTTLE CABLE | $0 | |
| 63852 | TRUNK LATCH 74850-S30-003 | $25 | |
