97 civic won't start
ok so im having trouble with getting my 97 civic to start the feul pump sounds like it os turning on its cranking but not turning over, fuel is coming out of the fuel line from the filter but in splurges. not steady. replaced distributor cap , plugs and wires it helped a lot and sounds closer to wanting to turn over but still isnt, replaced main relay also and thats all ive done, what else can i do and what is the firing sequence for the distributor cap and plugs
Just because you replaced the cap/plugs/wires (forgot rotor) doesnt mean its getting spark.
Do a test to see if its getting spark. If not, have the guts of the distributor tested. Most likely bad coil if there is no spark.
honvic
Dec 4, 2011 07:27 AM
