Thermostat housing ground wires
Hello everyone...i want to know how many wires for the ground(G101) are bolt on the thermostat housing?i am referring for a b18c type r wiring.Thanks.
i thought there's only one ground on the thermostat housing?
then there's one by valve cover, and another of course for negative terminal of the battery, for a total of 3 ground wires
Ok..if you look closer to ground attached on the thermostat housing,normally there are 4 wires merged into one connection..i think 2 black and 2 brown.but what seems weird with my wiring..there are only 3 wires..two brown and one black..i want to know where exactly those wires go to which pin in the ecu..so that i can trace them and make correction.
Yes sir,,i am much more concerned with the g101.i want to know where they are located in the ecu plug?I have checked almost of all my friends b16/b18 engines,they all have 4 wires(g101),but mine have only 3 wires.And i am currently experiencing very poor throttle response,running rich,we changed all sensors,ecu,dizzy,everything.but problem persists.No cel on.
Ok..but the wire black wire is missing in the connection?I'll look in the service manual and follow all the 4 wires in the ecu plug to the thermostat housing.Thanks for the info.
Three inches from the houseing you'll fine it's 3wires to 4 l just rebuilt mine do to no C.E.L. l to need that diagram.3 mounths now.OBD2a
On the fifth gen one black wire is strictly the Engine Coolant Temp Switch, the other black wire is split to the Heated O2 sensor, the VSS, pin 25 of the ECM and the Vtec pressure switch.
The other two wires go to a plethora of things.
I am not sure if it's the same design or pathways on the sixth gen.
For one thing, on the 5th gen, there is only 1 brown wire and it's brown/black, then a black/red then two plain blacks.
You probably might want to purchase the Electrical Troubleshooting Manual for your car from helm.inc it's not expensive and quite detailed on all the wiring.
Question about g101. Had a fan problem, so we tested some stuff and figured out the fan is fine, it runs with direct power off the battery. fuses and relays good. So yesterday I replaced the engine coolant temp switch and flushed the coolant. Also did spark plugs and wires while I was at it. I'm confident on the repairs. Problem is when I recranked it ran for a minute then idled down and died. Wont recrank unless I rev engine, dies when I let off the gas.
I think it's the thermostat ground wire. I loosened it to reposition when I replaced the switch. Never knew it would shut me down but I've read this is exactly what happens. So I've tried cleaning the terminal and the bolt and repositioning a bunch, can't get it to act right. It has the same 3 wire configuration, 2 browns on one lead and one black on the other lead. It ran fine prior to moving it, so i thinks its just being sensitive. Any thoughts?
You probably put the wires on in the wrong order
If you have a multimeter you can check resistance from that g101 terminal to the batt negative and thatll tell you if you have a high resistance reading
Dont just guess at repairs
Well we weren't guessing but it made me think about the order of the wires. Went back and looked at the diagrams and rotated our pattern 90deg to the right...perfection!
Thanks guys
Thanks guys
The guessing part of my post wasnt aimed at you.
It was aimed at people making blind suggestions
Good job on getting it going
I know this is an old post, but what order are the thermostat ground wires supposed to go in on the fifth gen?
gabrielsousa
May 21, 2014 08:21 AM
