stripping things for weight
Old Oct 24, 2002 | 07:13 PM
EFing8's Avatar
Default stripping things for weight
How much do the following generally weigh?
- Front Bumper Support/Impact
- Rear Bumper Support/Impact
- Side impact beams in the doors.
it is an 88 HF if you wanted to know. Already very light car but it's speed is based on weight, instead of adding more power i want to strip more weight. well...you know damn well i will add more power as well. Also if anyone else has any other suggestions for things to strip that would be great. I have already taken out the rear interior.
Old Oct 24, 2002 | 07:15 PM
Steve91's Avatar
Default Re: stripping things for weight (CND_CRX)
On the SI, I know the front and rear bumper beams weight 20lbs each. I've never weighed the door beams, but I don't think the 88's have them.
Old Oct 24, 2002 | 08:59 PM
EFing8's Avatar
Default Re: stripping things for weight (Steve91)
only 20lbs huh. hmmmm. still worth it to me . Off with their heads. I am thinking of taking out that really really heavy rear glass and putting in some lexan.
Old Oct 24, 2002 | 09:17 PM
crx(gator)'s Avatar
i say get rid of the windows for lexan (back 3) but leave in the bumper supports if your keeping it on the road, they may come in handy one day...if your making it an all out racecar, take out everything, this guy at n8 had a 1st gen crx completly stripped except for the guage cluster...car was hot...
MisterB's Avatar
i think the side impact beams are there for a good reason... if you drive the car regularly i would keep them there they could save your life
not worth it to me
2c
Old Oct 24, 2002 | 09:41 PM
EFing8's Avatar
Default Re: stripping things for weight (cl4show)
perhaps that is a good idea, I have wrecked 3 cars in as many years. It is a strange strange thing too. All at almost the same day and all near the same amout of kilometers on the cars. oh sorry MILES.
Old Oct 24, 2002 | 10:21 PM
spettinger's Avatar
have someone else drive your car around that bad time and bad mileage. tell them to put roughly 3000 miles, or 4800 kilometers (hope that's right, eh.) bingo. you are past the crash point, worry free. roll cage that sucker and do fiberglass doors and rear hatch. make the door section really crazy, to the point that you have to climb in the car from the hatch. nutso.
Old Oct 24, 2002 | 11:50 PM
Lost Type R's Avatar
Default Re: stripping things for weight (wreckedhatch)
take out the motor.. thats some big weight reduction
Old Oct 25, 2002 | 02:55 AM
thaiphob's Avatar
Nikon!!!
not worth it to me
2c
cars are replaceable...your life is one of a kind.
Old Oct 25, 2002 | 04:09 AM
keithv's Avatar
Default Re: stripping things for weight (thaiphob)
the glass is definitely heavy. have you ever changed the hatch supports? if so you'll feel how heavy the hatch is.
Old Oct 25, 2002 | 06:24 AM
incubus's Avatar
Default Re: stripping things for weight (Lost Type R)
lol! I agree.
Old Oct 25, 2002 | 05:42 PM
EFing8's Avatar
Default Re: stripping things for weight (incubus)
I have a spare hatch sitting in my basement. That thing is probably 100lbs. A nice fiberglass one and some lexan would probably save about 80lbs.
Old Oct 25, 2002 | 07:34 PM
JustChou's Avatar
Have you guys ever worked with Lexan?
I used it a lot on my battlebots, in any sizes from 1/8" to 5/8" thick. It is sooooo soft. It is designed to be soft. It scratches with a fingernail. Unless this is an all race car, don't recommend using Lexan to replace your glass.
(PS: there is optical grade, abrasian resistant lexan, but it's hella expensive, espeically in big sizes)
Old Oct 25, 2002 | 09:21 PM
MrTodd's Avatar
Default Re: stripping things for weight (JustChou)
There is one site that I've seen that sells fiberglass hatches for the CRX. You'd lose a lot of weight with this... Also, you can replace the battery with a drycell battery, they're like 10 lbs lighter - but fairly expensive. (can't remember the website I saw these at...sorry)
Also, another reason to keep the front & back bumpers is because they help stiffen up the chassis a bit. Keep those puppies on.
[Modified by MrTodd, 11:22 PM 10/25/2002]
Old Oct 26, 2002 | 01:53 AM
AussieK24's Avatar
FYI, I have a 3 gen Civic and the hatch weighed 41 lbs stock, now weighs 14 lb with gutting and lexan.
Old Oct 26, 2002 | 09:39 AM
Urban Business
Guest
Posts: n/a
Default Re: stripping things for weight (b16a4me)
id take out bumper suports and side impact beams only if you have a very well designed cage. i dont even see how the side impact beems would work. 4th gens are soo small and thin. im deathly afraid of my car. taking out what ever saftey suports and **** it has from the factory would scare me even more.
i hit 1715 with bumper suports, impact beams, stock wheels, stock glass. stock hatch stock crossmember.
oh lexan does scratch very easily. there is a wax or a polish tht you can put on it regularly to prevent it. you can also buy it scratch resistnt. a thin layer or clear coat may even work to keep it scratch resistant.
[Modified by TorteX, 12:40 PM 10/26/2002]
Old Oct 26, 2002 | 10:16 AM
MisterB's Avatar
Default Re: stripping things for weight (TorteX)
dang how did you get it that light is it fully gutted what all did you take out?
you want to hook me up with that spare hatch i have some one that will make me a CF one but i need to give him an extra one to work with
tRex99
20
Feb 14, 2005 08:29 PM
*Boostwerks*
18
Nov 18, 2004 01:01 PM
PM-Performance
May 28, 2004 09:45 AM
AK94GSR
May 5, 2003 06:50 AM
crooked muffler
Jan 21, 2003 08:48 PM
