Honda S2000 Honda S2000
Car dies under load
Old Jul 22, 2013 | 06:37 AM
hungrygreen_gsr's Avatar
Default Car dies under load: Fixed
I have a 2003 S2000 all stock with 122,xxx miles. Two days ago I was driving along and my car just dies out of no where. All electrics shut off and gauge cluster goes dark. All my warning lights come on and then car shuts off.
I figured my alt took a crap so replaced it with a unit for AutoZone and grab a new battery to boot. Put everything in and it still does the same thing! I checked all my fuses and everything is good.
Any ideas what this could be?
Edit: the car will idle fine and not die. It only happens when give it gas. Happens in neutral and in gear.
Thanks
Old Jul 22, 2013 | 11:55 AM
GhettoNinja06's Avatar
Default Re: Car dies under load
Wow, that's really weird :/
Check your harness and make sure it's not burned or cut anywhere. Also check the harness connections to everything especially the ECU. Also check the grounds.
If none of the above then it could be a bad ECU.
Old Jul 22, 2013 | 12:59 PM
I did do all of those checks you mentioned. I'll see if I can locate an ECU to swap in and see if that fixes the issue. I also read a lot of people having issues with the MAP sensor. So that's 2 things I'll check out.
Old Jul 25, 2013 | 10:16 AM
Did some further digging and it ended up being a crop of bad wires leading into the fuse box under the dash. Fixed 'em and problem solved
Old Aug 25, 2013 | 06:00 AM
JDM-sol 89's Avatar
Glad to hear you got it solved.
projectLx02
Sep 9, 2011 08:38 PM
2point1
Jun 22, 2010 03:55 PM
turboteg90
Jun 15, 2008 06:12 PM
LSTEG98
Apr 3, 2008 12:14 PM
wafro
Aug 23, 2006 03:43 AM
