'90 accord failed CA. smog, need advice
car is an automatic...all stock w/over 200k miles... I knew it would fail smog but not this bad!!
any advice is appreciated! besides adjusting the timing (forward) and installing a new cat. converter....would i need to do more work, or would that be enough to pass smog??? (car is old, tryin to avoid investing too much $)
With all 3 being high I would assume it's the cat. Advancing the timing will help a little but, I think you're still gonna need a new cat. A new cat should work to fix the problem unless the engine is just worn out.
I forgot to mention/ask about the failed egr valve; could somethin else cause the egr to show "failed" I.e. if smog numbers are just so bad, its too much for the egr to work? Or is that gonna need to be replaced too? Thanks again!
Yes, you have an egr valve. I'm not sure why it's saying "not applicable".
I would first pull the egr plugs(or have a place that specializes in Hondas do it) and clean out the ports and egr valve and do a pretest just to see if you can save on the cat. But given how bad your results are it would appear that you are going to need to replace the cat too, but take a chance on not having to if you can.
And yeah you will need to get the timing back to specs...it needs to be 15 +- 2 degrees...but try to get it exactly at 15.
OVER 8% O2?
This should be ~.1%Only 8% CO2?
This should be ~15%This would seem its running very lean, possible misfiring which would cause high HCs... But CO% is .7... oh that's after cat, so its probably higher due to combustion issues.
Fix the timing, clean the EGR ports, verify EGR valve works, verify ignition system is up to spec. And hell sea foam the bitch with a couple of cans.
http://www.autoshop101.com/forms/h56.pdf
http://www.autoshop101.com/forms/h64.pdf
http://www.autoshop101.com/forms/h61.pdf
Read 'em. Learn 'em. Love 'em.
The above PDFs are from Toyota but the basic emissions systems work the same amongst applicable cars.
Your CEL light must work as that is part of the emissions test. No codes at all?
619? Damn and I thought holmesnmanny was South
(bad Bay Area joke).
OVER 8% O2?
Wooden, actually. Silver/Magical sword had the geezer say "Master using it and you can have this.".
... damnit... now I have Ganons level music stuck in my head...
dune-dune-da-dune, dun-dun-dun-dun-dun-da, dune-doon-da-doon, da-dune-doon, da-dune-doon-DA-DOON DOON DA DOOOON...
Nah, installing a new cat would most likely just net you a new dead catalyst in short order. There is some running issues with your car.
What kind of mileage(MPG) are you getting.
Print out the 'h56.pdf' and go over it. Note the bold sentences they are the nuggets.
Originally Posted by hatchinprogress
I was hoping I could just get a new cat. Installed and that would be enough to pass.....guess I wasn't that lucky.
Update! The catalytic converter was hollowed out...... had exhaust shop replace it....when I looked in the cat, I could see right through it Lolz ....new cat. And an exhaust leak welded up....... now car is putting out clean emissions.... but it failed Cuz the timing was at 7* btdc, I'll update after I adjust timing and re test smog
efnoobie
Aug 1, 2009 01:42 PM
