Suspension
92 Wagon Ex... I think I wanna get the Koni shocks/struts for my wagon but I am not sure what springs to get. It is my daily driver and I want it to be lowered; however I do not want it to be stupid slammed as it is now..with ebay cheaps...Also I do not want it to be hella bouncy as it is now. So, what would be a good setup and where would I find it for good quality...I would just like some good setups and detail of the ride quality from experienced people. thanks!
# 4011.140 PRO-KIT Performance Springs (Set of 4 Springs) Lowers F/R- 1.2"/1.2"
# 4.1140 SPORTLINE Kit (Set of 4 Springs) Lowers F/R - 1.8"/1.7"
Contact info:
1-800-507-2338
Eibach Springs, Inc.
264 Mariah Circle
Corona, CA 92879
They can also recommend the correct shock/valving for their springs.
Could be a couple of things, but usually when a 'popping' issue is created with a coilover style shock assembly it is from the shock extending past the free length of the spring. When the suspension compresses back down to the springs free length the spring reseats onto the perches with a pop or bang.
This can usually be corrected by adding flat coil springs, also known as helper springs to prevent the normal coil springs from banging around at full droop.
http://e30m3project.com/e30m3perform...-tech/springs/
Here's a link(miata) on seeing the helper work.
http://forum.miata.net/vb/showthread.php?t=405671
2000EX WhiteMagic
Suspension & Brakes
Feb 13, 2009 12:20 AM
stripes777
Suspension & Brakes
Sep 20, 2006 12:30 AM
rossockr
May 7, 2003 07:03 PM
