my built gsr won't stay on
Old Jul 20, 2013 | 03:38 PM
edgar62810's Avatar
Default my built gsr won't stay on
Ok so I recently built my gsr it's in a 92 hatchback it's on a base map on a hondata s 300 so I go to turn it on and won't stay on with out me pressing on the gas peddle I have double checked everything plenty of times and still can't find out what it is fuel pressure is at 45 compression 145 all around timing is set perfect can someone please help!?
Old Jul 20, 2013 | 03:48 PM
grumblemarc's Avatar
The Grumpiest
Default Re: my built gsr won't stay on
That compression is kinda weak. What happens if you use an unmodified/stock ECU?
Old Jul 20, 2013 | 04:45 PM
jbpnoman's Avatar
Especially weak for a GSR.
What injectors are you using? Are you throwing any CELs? You call your engine "built", what about it is built?
Old Jul 21, 2013 | 07:11 AM
Former User's Avatar
Sounds more like a low idle problem. CEL codes? Clean IACV and FITV? Adjust idle speed?
Shiznit028
Aug 18, 2014 07:59 AM
ohsnapzafingcu
15
Jun 7, 2010 09:07 PM
NosShootinHonda
Mar 10, 2009 06:51 AM
b20vcrxsir
Sep 25, 2008 02:50 AM
Kdiddy
Apr 5, 2007 12:45 PM
