1999 Acura El won't turn over
Last fall I purchased this automatic 1999 Acura El (d16y8) with a bad block from a friend. Over the winter I replaced the block with that of a y7, put everything back together and the motor won't roll over. I've tried 3 starters now that haven't worked:
1. The starter that came with the car (worked before block seized)
2. Old starter i've had sitting around for years
and 3. Starter i just got at the junkyard 30 mins ago.
Battery is fully charged, i've been taking it out of my daily driven hatch to try starting the EL. Battery terminals are making a good connection, fuel pump is priming (so not main relay??), I even tried my old battery-to-starter wire from my old 1995 auto hatch and still nothing but a click..
I have the transmission ground, the thermostat ground, a ground to power steering pump and added one to valve cover as well
I checked the fuses under the dash
Video trying to start it:
http://s1132.photobucket.com/user/eg...67fef.mp4.html
Before tear down:
Before tear down:
Just for clarity, is the motor trying to turn but not starting, or is it not trying at all?
In addition to what RonJ said, are you getting spark? Spark is easy to test, just need to get a spark tester from your local parts store. Should be about $15. Looks like a spark plug with no threads on it.
Once again, what RonJ said. Also, you can jump start an automatic car, you just can't push start/bump start it.
Do you have a voltmeter? If you do, how much voltage to you measure between the positive and negative battery terminals? On the main power terminal for the starter, do you have constant battery voltage? With the key turned to ON(III), do you get 12V to the starter signal wire (smaller blade terminal)?
I also confirmed the thermostat housing ground is making good contact and I made sure the signal wire is making good contact but still nothing
I found a new multimeter tool in my shed. 12.76 is the reading I am getting between the 2 battery terminals. While holding the red multimeter cable on the starters main terminal, and the black cable on the negative battery post, i still get a 12.76 reading. Also with positive cable on starter main terminal and black cable on where signal wire connects I still get a 12.76 reading.. this is all with the key turned off. I'm unsure how to check for constant battery voltage
Edit: I also got the stereo security code from Acura in hopes it was the security system not allowing it to start but still nothing. At least the radio works?.. lol.
So your battery is OK.
Go to your local parts store and buy a spark tester. It looks like a spark plug without threads, like this.
Follow the directions on the packaging, and check for spark on each of your wires. You should have a bright white spark. Tell us if you get spark, and what color it is, on each wire.
^^ lol how is it going to spark if it isn't turning over?
simple... pull the starter out and see if it spins on it's own with the key. so remove it, hook it back up while being careful to NOT short out things in the area with the live terminal... remember it's going to flop around if it does try to bump... so wrap the terminals up with a bunch of rags and electrical tape while trying this. have a friend turn the key while you watch the starter. if the bendix comes out to engage the flywheel (torque converter in your case) and the starter spins, then you have an engine issue. try to turn the engine over by hand using the crank pulley bolt or hex relief.
if the starter does not run outside the engine on it's own, then run a separate (min 12 gauge) wire direct from the battery to the starter post. does it turn then? if it does, then you have a starter relay problem. if it does not, then you have a starter problem.
i should mention, remember to ground the starter body to a nice ground (like the engine block). I find a bunch of spare aligator clamps of all sizes make for good testing leads you can just make up as you need with spare wire.
Again, as far as I know, fuel has nothing to do with the engine turning over
Also, is it as simple as running a 12 gauge wire from the positive battery terminal to the starter terminal? The oem wiring also has a wire going to what I believe is an ABS module/box of some sort, and another wire going into the fuse box beside the battery. Would these need to be in place for the starter to crank the motor?
I believe the y7 block has no knock sensor. I was going to swap it in from the old y8 block but it broke off after basically touching it. Would this have an effect on anything?
Also, could it be something to do with the torque converter binding? This is my first time working with an automatic
- With the meter set to read DC voltage, touch the red meter probe to the large starter motor terminal and the black meter probe to the surface of the starter. Note voltage.
- Next do the same test but touch the black meter probe to the top of the transmission. Note voltage.
Unplug the starter solenoid wire. Have a buddy hold the ignition key in ON(II). Use your multimeter to measure voltage between the disconnected solenoid wire and the negative (-) battery post. What is the voltage reading?
I unbolted the starter and got someone to watch it while I turned the key to start the car. The starter still does nothing. I'm starting to think all 3 starters I have tried are bad, I'm going to buy a new one tomorrow from napa and see if that fixes it.
I just checked, starters still unbolted. 4.38 on clean spots where bolts go through. The rest is dirty and reads below that
12.68. I also tested battery and it was 12.68 as well.
I couldn't get a reading any higher than 1.1volts
Try this test:
While not impossible, the chances that this^ is correct are exceedingly small.
This^ is clearly the problem. Voltage is not reaching the starter solenoid from the ignition switch.
Have you tested the ignition switch?
Key OFF:
Only the wire 'A' had a reading which was 12.48volts
Key ON(II):
All wires were reading about 12.1volts EXCEPT wire 'D'
Key ON(III):
I read 12.33 on wires 'D', 'E', and 'A'. I believe 'B' had a reading of 0volts and 'C' 0.48volts
