Honda CR-V & Element 2WD & 4WD Element & CR-V
98 CRV power window control module
Old Jul 18, 2013 | 11:17 PM
swordofdoom's Avatar
Default 98 CRV power window control module
Aside from the main window switches and fuse is their another window control module for the windows?
My Drivers window won't go down along with the rear passengers. I've replaced the driver regulator and got no results. Changed out the main power window switch with a used one and still have the same problem. I did a voltage test on the two R/B and R/Y wires that feed the motor and im not getting any voltage to them when the switches are pressed and I also checked to see if they are actually connected back to the main switch which they are. Also checked all window fuses and they are also getting voltage.
I'm stump on this problem and any advice would be helpful
Old Jul 19, 2013 | 10:11 PM
Junior323's Avatar
Default Re: 98 CRV power window control module
inspect the wires that are in the wire loom between the door
Old Jul 20, 2013 | 09:08 AM
richmond's Avatar
i actually just went through this with my cr-v, i bought a door module because my door locks and remote stopped working, then I removed the door panel and uplugged the harnesses and the body side harness had wires broken at the pins.
Chrisxnj
10
Dec 6, 2016 01:21 PM
pdubbs
Jun 18, 2016 06:02 AM
Basilias
Dec 29, 2010 06:57 AM
eg6sir88
Mar 24, 2010 06:25 PM
mark2583
Sep 16, 2007 04:46 PM
