The Accord is sick...
Old Jul 18, 2013 | 05:07 PM
thecyclops's Avatar
Default The Accord is sick...
Near immediately after getting gas at an unfamiliar station (Coincidental?) ,the speedo on my 97 accord starting going haywire and the car struggled to get going after coming to a dead stop,but after the car starts moving it seemed better.
The check engine light came one,but I did make it home.I went back out later to have advance check the code when it got MUCH worse.Same speedo jumping,with more severe "hesitation" from a stop and the D4 light started steady blinking non stop.The D4 light blinks one long blink upon starting vehicle.
Just got the car maybe a month ago,seemed to shift "hard"but really no harder than a honda this age and mileage at 179,000.
Any advice is appreciated.Thanks.
Old Jul 18, 2013 | 08:02 PM
Mishako129's Avatar
Default Re: The Accord is sick...
You have a bad speed sensor, its a very simple and common fix. There are two 10mm bolts, you need a long extension and a 3/8 socket wrench. Find the sensor off ebay for $10 and install it yourself. Its easy.
A bad speed sensor will cause all of the problems you are describing.
From now on I would unplug your speed sensor if you don't want your car to hesitate from a stop. Until you replace it.
Old Jul 19, 2013 | 08:43 AM
Lost Again's Avatar
My question - what are the codes?
Old Jul 19, 2013 | 02:28 PM
thecyclops's Avatar
I found the list of codes by googling my issue (Actually I believe the thread it was found in was on this forum)
The D4 light while operating is just flashing,but when you turn off car for few sec then restart the D4 will flash a code,kind of like morse code....Like 1 slow blink,or 5 fast blinks,etc.Mine is one long,slow flash.
Thanks to the other poster for the VSS suggestion.I actually read this a few times,but would the "code" for this be the "one flash"?
Old Jul 22, 2013 | 10:03 AM
thecyclops's Avatar
OK well it was the VSS!!! I got it towed by my mechanic (VERY honest man) on Friday and being picked up today,but NOT cheap.
Total for the tow/part(s)/and labor......Drum roll please......$292!!!! OMG!!! Basically the tow was 75 and the VSS was 75 (From advance) and also a wire?Not sure about that but the wire,VSS,tow and labor was 292.
Old Jul 22, 2013 | 12:21 PM
MAD_MIKE's Avatar
MM Gruppe B
No.
To properly pull the code(s), look under your glovebox door, there are two blue electrical connectors. Pull down the one with two wires. Jumper the two wire connector with a piece of conductive wire. Turn the car ON(not start) any codes will blink from their applicable warning light CEL=engine related, D4= transmission related, ABS= ABS, et-cetera.
Old Jul 22, 2013 | 01:46 PM
Mishako129's Avatar
You coulda got the VSS for $10 on Ebay. I had a bad VSS and got mine for less than $10 and its worked for me now for almost 5 months.
That sucks man, you shoulda listened to me, it would have saved you a lot.
Why was your car unable to drive? Maybe you shoulda unplugged the VSS, it might have helped....
Old Jul 23, 2013 | 10:24 PM
thecyclops's Avatar
Well I know my mechanic is honest and specializes in imports.When I picked up the car he said they worked a few hours on it on Saturday,and replaced the VSS but it still wasnt right.Thats when they replaced "a wire" on monday,and that was the majority of the $$$ was them trying to figure out why it still wasnt right,which in that case,I wouldnt have been able to fix it.He apologized but I suppose they just had to track it down.
When I drove it around halfway to the mechanic it really started stalling/stuttering so I just turned it around and came back home.Had I known that I could have made it (I suppose I could have?) I would have at least saved myself some tow money.
The reason I say they are honest is they have blatantly saved me money before(well its a business,not just a mechanic) like quoting me X amount,,and then when I return say that it was a little less labor,or that they were able to fix something cheaper,etc.
Old Jul 23, 2013 | 10:33 PM
YellowBacteria1's Avatar
12$ for the speed sensor
80$ for the inspection
200$ for the install
standard rape.
Old Jul 29, 2013 | 08:35 AM
thecyclops's Avatar
It says...
TRANSMISSION DIAGNOSIS-(INCLUDES PRESSURE,STALL,AND ROAD TEST.CHECK SHIFT AND THROTTLE CABLE ADJUSTMENTS-$63.70
REWIRE SPEED SENSOR-$49.00
SPEED PULSER(E.A.T)-R&R-$25.00
TRANS SPEEDO SENSOR-$73.49
TOW-$65.00
CricketThomas
12
Jan 30, 2017 06:37 PM
FunkTechNician
Feb 1, 2011 02:31 PM
jusdoit302003
Jan 18, 2011 11:07 AM
NIKE4FRESHH
Feb 8, 2009 12:44 PM
zak88lx
Jun 5, 2007 01:33 PM
