d15z6 build piston/ set up help
Old Jul 18, 2013 | 07:03 AM
boosted panda's Avatar
Post d15z6 build piston/ set up help
hey guys im planning to start my mini build and need to know if its safe to run d16 pg6 pistons with d15 rods
-d15b7 block
-d16z6 head
has anyone ever tried this combo i checked the set up on http://www.zealautowerks.com/dseries.html and it says its safe.I wanna be sure before i start. thanks
Old Jul 18, 2013 | 07:12 AM
JuggerNaut-CTR's Avatar
Default Re: d15z6 build piston/ set up help
What are your intentions with the motor? Boost?....All motor?....
9.9:1 comp is pretty low...of coarse it's safe, Its a pretty low/mild dome.
D15 rods suck by the way. Brittle little twigs.
Old Jul 18, 2013 | 07:16 AM
Post Re: d15z6 build piston/ set up help
i plan on boosting it
Old Jul 18, 2013 | 07:17 AM
grumblemarc's Avatar
The Grumpiest
With D15 rods? Not a smart idea.
Old Jul 18, 2013 | 07:39 AM
I assume I would need to have custom length rods
Old Jul 18, 2013 | 08:34 AM
The Grumpiest
Maybe you want to mention all these things before asking a question that cannot be answered accurately when this information is lacking.
Old Jul 18, 2013 | 08:39 AM
X E Ryder's Avatar
I run D15 rods (oems) for a mild build D15B7, I have been cautioned numerous times not to exceed 8000rpm, 12:1 compression, or boost while running them.
Boosting opens a whole nother chapter to what you should be doing to that motor - if you want it to live. There are some decent build threads for all motor SOHC D motors - and it might give you plenty of go that lasts, for less $$
Old Jul 18, 2013 | 01:15 PM
my goal is about 200whp and i kno d15 rods have limits that arise quickly when boost is added into the equation. i want to go forged internals but from other research on the forum i have found out that the market for the d15 is very limited if existent at all. i dont mind spending the money to do it right i just want it reliable at the end of the day
Old Jul 18, 2013 | 03:40 PM
The Grumpiest
If you already know your options are limited, what is the point of the question? You have Crower and I think someone mentioned CX Racing had offered these for a while.
Old Jul 21, 2013 | 01:42 PM
ok after looking into a few setups im planning to go with cx rods and pg6 pistons
Old Jul 22, 2013 | 03:29 AM
The Grumpiest
No. You won't.
Old Jul 22, 2013 | 04:12 AM
Originally Posted by grumblemarc
No. You won't.
Co-Sign...
Old Jul 22, 2013 | 07:12 AM
with widened valve reliefs the combo would not work?
Old Jul 22, 2013 | 07:17 AM
The Grumpiest
What does that have to do with you thinking you're going to use aftermarket rods with stock pistons? And what setups did you look at where this has been done? Or why you're trying to push such high compression on a turbo build? It can be done with a precise tune but you don't seem to be at that point to pull it off.
Old Jul 22, 2013 | 08:04 AM
d16a6 block with a z6 head was all i could find with that piston set-up, my goal is not high compression but getting ahead of myself i did no look into every detail as i should've i have looked into turbo builds and the ones i have seen start with ~ 9.** cr so now looking into other more rational combinations the 134.5 cx rods with Pm6 pistons would yield a cr of ~9.21 with 0.03mm deck clearance. At this point I'm not sure any modifications are necessary
Old Jul 22, 2013 | 08:29 AM
The Grumpiest
Again. Where did you read that aftermarket rods are even compatible with stock/OEM pistons? As far as I know they aren't.
Old Jul 22, 2013 | 09:19 AM
94AnaHonda's Avatar
They would be compatible if the wrist pin diameter was the same. But just like they're saying why would you want to do that anyway. Save your money and go aftermarket on both, especially if you're going to boost.
This --> https://honda-tech.com/forums/forced-induction-16/forged-rods-oem-pistons-2112138/
Old Jul 22, 2013 | 09:48 AM
The Grumpiest
Stock pistons are press in are they not? Where aftermarket uses a floating wrist pin. Am I mistaken?
Old Jul 23, 2013 | 07:27 AM
94AnaHonda's Avatar
No, you are correct. Most aftermarket rods are designed to use floating wrist pins that are held in place by clips in the pistons. OEM pins are pressed in the rods and the OEM pistons don't have clips in the pistons. Stock pistons can be machined for clips but there goes the budget. So, again go aftermarket on both. Sorry for the slight confusion Grumble and OP.
Old Jul 25, 2013 | 05:31 AM
thank you guys. im still looking for a combo that will work i have seen post in the forced induction section where vitaras and acl rods were used but cant find the acl rods anywhere. if u guys have any suggestions im all ears thanks again
Old Jul 25, 2013 | 05:35 AM
kyden's Avatar
there's no such thing as acl rods. the common rods used in d series were fjt.
Old Jul 25, 2013 | 05:36 AM
Suggestions....
Get a block that has more aftermarket support. I dont see the benefit of building a 1.5 liter anyways. Even boosted ones arent that great. Well from what ive seen on youtube.
Old Jul 25, 2013 | 07:20 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Just save yourself the headache and get a complete Z6 engine.
Old Jul 25, 2013 | 10:53 AM
im not going for huge power i just want a fun DD and experience the build my mind is made up on doing a mini me. does anyone kno how much fj rods run i looked on a couple post on dseries.org and didnt find to much on it.
Old Jul 25, 2013 | 10:59 AM
doctorake's Avatar
Community Builder
people are telling you a d15 is a poor choice but you are not taking advice. Why even post on here.
