Transmission & Drivetrain Gearboxes, Differentials, Clutches
flywheel question manual to auto
Old Jul 17, 2013 | 08:48 PM
SkylerTheG's Avatar
Default flywheel question manual to auto
will a manual transmission flywheel fit in a automatic transmission ?
is the manual tranny flywheel lighter then the automatic tranny flywheel?
Old Jul 18, 2013 | 05:09 PM
94EG8's Avatar
Seagull Management
Default Re: flywheel question manual to auto
Automatic transmissions don't use a flywheel period. They use a flexplate and a torque converter. No they do not interchange.
Old Jul 19, 2013 | 09:58 AM
SkylerTheG's Avatar
they dont use a flywheel i swear i jammed it to get off the crank pulley....
edit.
or is that just what the flex plate and torque converter look like?
wouldnt that mean i would need a flywheel to make it manual to?
Old Jul 19, 2013 | 10:38 AM
kyden's Avatar
yes you would need a flywheel to make it a manual transmission. it's what the pressure plate bolts to.
Old Jul 20, 2013 | 03:36 PM
jelcivic's Avatar
make sure you use flywheel bolts. the flex plate bolts are weaker.
zccr-xsi
May 24, 2006 02:28 PM
fasterthenmost
Nov 9, 2005 04:24 PM
92civichatch1
Oct 13, 2005 06:21 AM
SpoonFedHatch
10
Feb 20, 2003 07:09 PM
lunarcry
Jan 9, 2003 11:53 PM
