Auto to Manual???
Auto to Manual???
Hey guys I got an automatic b18b1 engine and i would like to know how to convert it to a manual. do i just remove the disc and replace with a flywheel? Has anyone done this before and can point out anything that could help me. Below is a pic to show you guys what i am writing about. The seems to be 8 bolts or pins in the middle circle. Can i just remove the pins and replace with flywheel?
Thanks in advance...
Re: Auto to Manual??? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Your going to need a manual flywheel, manual flywheel bolts and everything else. </TD></TR></TABLE>
nuff said
take off the auto bolts and throw them in the garbage, do not attempt to use
yeah i did get a manual flywheel, pressure plate, and clutch all from a b16 with less than 10k but i did not get get the bolts for the flywheel ... guess i got to go to honda... or does anyone know the size ... so i could try a local hardware store???
Imperious: Mod of Valor
Ding ding! We have a winner. This is correct.
Re: (hatchi)
dude do NOT attempt to get the bolts at local parts place...go to honda dealer they will charge u lcrazy amount but they are what u need i just did a auto to manual. the pressure plate and flywheel bolts cost $62. 14 bolts.
make sure u got a ecu for the gsr thats for manual.
got the clutch kit
flywheel
slave cylinder
clutch master
clutch pedal
got the clutch kit
flywheel
slave cylinder
clutch master
clutch pedal
LimpSalamander
01-09-2019 12:24 PM
Bruce Banner
02-09-2007 07:45 PM
