IACV B18b Swap
Old Jul 17, 2013 | 07:33 PM
MyWhiteEJ6's Avatar
Default IACV B18b Swap
Hey Honda-Tech Forum,
I swapped my D for a B and I'm using the wiring harness from the D. Everything plugs up except the IACV.. The D came with a three pin female connector and the B18 IACV is a pin two pin male. I took pics.. I want to know what is my next step
Old Jul 17, 2013 | 07:46 PM
Marvin1985's Avatar
Default Re: IACV B18b Swap
That plug isn't iacv. Think it's Evap solenoid plug. If your b18 is obd1 you can ditch it cuz it's an obd 2 sensor for emissions
Old Jul 17, 2013 | 07:54 PM
MyWhiteEJ6's Avatar
really?
Old Jul 17, 2013 | 08:12 PM
Marvin1985's Avatar
What year is your car?
http://www.ff-squad.com/tech/wiring/...-98_a-plug.jpg
There's 1 for 99-00 civic also.
You cut the 3 wire plug and use the 2 wire plug, color match the wires and leave the 3rd wire(orange one) off. Then move the wire at the ecu plug and done
Old Jul 17, 2013 | 08:16 PM
EG love's Avatar
The car is an EJ6? I know when swapping my obd1 b18b1 into my 93 eg si i had to cut back the wire loom so that my iacv and iat plugs would reach the sensors, since the iat sensor moved from the back of my d16z6 intake manifold to the runner on my b18b1 manifold. That's all I did on mine
Old Jul 18, 2013 | 04:54 AM
nealnanoHX's Avatar
100% correct.
Old Jul 18, 2013 | 06:22 AM
MyWhiteEJ6's Avatar
Originally Posted by nealnanoHX
100% correct.
Yes it's an EJ6. 98 CIVIC LX
Old Jul 18, 2013 | 10:32 AM
Marvin1985's Avatar
I have a 01 ls going into my 99 hatch so I'm doing all this as well. I'm just a little farther down the path. I'm running a chipped p28 ecu with jumper harness on my stock sohc dx harness. I eliminated all obd2 sensors and misc emissions crap like the evap box thing and rewrapped my harness. Still need to get myself a clutch and all fluids to start it up. Being delayed cuz I have a new front end out to paint I'm waiting on.
Old Jul 18, 2013 | 10:33 AM
Marvin1985's Avatar
https://honda-tech.com/forums/showthread.php?p=48795245
Use this to id plugs
Old Jul 18, 2013 | 03:09 PM
HondaPartsHero's Avatar
Technical Hero
That's either an IAT, EVAP purge or the charcoal canister purge. It's not IACV and those instruction don't apply. What color are the wires?
Old Jul 18, 2013 | 06:19 PM
MyWhiteEJ6's Avatar
I believe that You're all wrong. The IACV has two hoses coming off of it. I located the old IACV three connector plug. All I have to do is find a two pin plug remove the orange wire and rewire my ECU.
Old Jul 19, 2013 | 01:31 AM
Technical Hero
What are you talking about? Everyone is correct including you statement above. Above is listed the instructions on how to convert your 3 wire to 2 wire which would be correct. And as I listed above that plug you posted in the first post is not the IACV plug but rather it is either the IAT (which will not plug and play with the b18 but you can use the civics IAT in the intake arm), Evap purge or charcoal canister purge.
Old Jul 19, 2013 | 05:20 AM
kyden's Avatar
^^ that.
Old Jul 19, 2013 | 06:07 AM
MyWhiteEJ6's Avatar
Thanks !! Lets identify these parts for me
Old Jul 19, 2013 | 06:20 AM
kyden's Avatar
upper right part is purge solenoid. middle part is map sensor.
Old Jul 19, 2013 | 06:24 AM
MyWhiteEJ6's Avatar
AS far as the swap is concerned.. Do I need the Purge Solenoid? I don't remember having one with the D16
Old Jul 19, 2013 | 07:45 AM
Technical Hero
Your's was on the fuel rail. If you are staying OBD2 USDM on the ecu you'll need it hooked up or you'll throw some codes.
Old Jul 19, 2013 | 12:05 PM
MyWhiteEJ6's Avatar
Pics please
Old Jul 19, 2013 | 03:26 PM
Marvin1985's Avatar
Bro wtf I've explained it for you. The plug you have pictured is to that purge solenoid on the intake manifold. If your going odb1 You don't need it.
Your iacv issue is what I posted already. Get the correct plug and wire it up. Done. Cap the purge off.
Old Jul 19, 2013 | 04:50 PM
Technical Hero
I didn't see where he said he was going obd1 though. Sorry the y8 is on the fuel rail the y7 is to the top left of the throttle body
Old Jul 20, 2013 | 08:09 AM
MyWhiteEJ6's Avatar
Marvin,I got it man.. Thank you
turbo sol
Mar 29, 2009 09:47 AM
namewasdallas
11
Jan 7, 2009 01:14 PM
turbo-crx
Sep 30, 2008 10:00 AM
arrojj
Jan 3, 2007 07:54 PM
dohdoh420
Sep 11, 2006 10:30 AM
