Stumped fan wont work
Old Jul 17, 2013 | 06:47 PM
apexi_rsx's Avatar
Default Stumped fan wont work
ok ive swapped out my fan switch with another one and it worked for alil bit then stopped again. so for the mean time I jumped the fan switch so it is on constant now... I let the car get up to temp and over heat alittle and I took the relay out and put it back in the fan comes on .I replaced the relay with another good one and as the car warms up the fan will not work. if I pull the relay and put it back in my fan comes on. I used a voltmeter and checked connectivity going through the fuse box and everything checked out using the OHMS. so there isn't any shorts as I checked it all the way to the fan switch from the fuse box. anyone have any ideas?
Old Jul 17, 2013 | 09:39 PM
Former User's Avatar
Default Re: Stumped fan wont work
Maybe the fan itself is on the way out.
Old Jul 17, 2013 | 10:09 PM
apexi_rsx's Avatar
it works fine when jumped ... I may try just buying a new fan switch and see if that bites the bullet
Old Jul 18, 2013 | 01:45 AM
jmarshall098's Avatar
If the Temperature gauge reads normal at Dashboard and the fan not work at all, then it is more likely that the Thermostat sensor has gone bad which is preventing the fan from starting. It can also be possible that the fan fuse has gone wrong. Try replacing the fan fuse.
Old Jul 19, 2013 | 07:04 PM
apexi_rsx's Avatar
ive replaced fuses and swapped relays with another working one... the gauge sensor I just replaced and that's a single wire sensor straight to the gauge the ecu has its own sensor on the side/front of the head to send signal to the ecu. I swapped the relay to the blower and the relay worked fine on the blower.... my only guess would be the fan switch going bad again...
Old Jul 19, 2013 | 07:43 PM
If the fan runs continuously with the switch connector jumped, then either there's air in the cooling system or the switch is bad.
Si joey
Oct 21, 2015 09:39 PM
19 crx 89
10
Aug 26, 2010 12:38 PM
littleblue
Oct 14, 2008 04:44 AM
Paluce
Mar 20, 2007 09:33 AM
og asr
Jul 4, 2005 12:33 AM
