fuel cut of really early? and kinda sputtering up to speed
Old Jul 16, 2013 | 09:06 PM
Dat EF Doe's Avatar
Default fuel cut of really early? and kinda sputtering up to speed
I have a 1990 ef hatch with a ZC block and a D15b head with a dual point :'( lol. I was wondering if the dual point was the guaranteed problem for this. first and second gear end HELLA fast. its not even funny. and the car when i get to higher RPMs trying to gain speed the car kinda sputter. like it was not getting enough gas or something. i am assuming that this is because of the dual point. is there anything else that will cause this and can i make a dual point fast?
Old Jul 17, 2013 | 07:50 AM
4drEF's Avatar
Keyboard Humorist
Default Re: fuel cut of really early? and kinda sputtering up to speed
You are in luck!
You can make DPFI really fast!
All you need to do is convert to MPFI!
Seriously - nothing you can do.
I would be worried about that sputter being detonation.
Old Jul 22, 2013 | 03:45 PM
turn&burn89's Avatar
Originally Posted by 4drEF
You are in luck!
AHAHA i was thinking after the first two sentences there really was something, but no man you're SOL on that one. is the ecu for DPFI or MPFI, dumb question probably.
gears end fast? that'd be transmission related...
could be TPS any CEL check the ECU under the pass. floor board
kop-O-nen
Jan 2, 2010 11:45 AM
anek
Oct 19, 2007 12:52 PM
psychadelicfreedom
29
Jan 9, 2004 01:00 PM
Team 4
Sep 15, 2002 06:35 AM
wuhungsixxx
17
Sep 14, 2001 02:26 PM
