90 dx hatchback build still learning
Old Jul 16, 2013 | 08:04 PM
lucky luciano24's Avatar
Default 90 dx hatchback build still learning
i have a 90 hatchback d15 and gunna have a 91 si d16. my 90 has headers aem intake and msd set up with wires. im looking to fix it up but need sum help on were to start pretty much still learning everything so if anyone can help that would be great and il post some pics of the car when i get a chance
Old Jul 16, 2013 | 09:07 PM
Dat EF Doe's Avatar
Default Re: 90 dx hatchback build still learning
I am a little confused on what you are talking about. lol, If you are having trouble starting i would say swap the engine first lololol..
Old Jul 16, 2013 | 10:25 PM
89 SI zero's Avatar
help on swapping the engine in?
Old Jul 17, 2013 | 01:26 AM
well im getting the d16 to put in my car for two reasons one is because the 15 is a little run down when i got the car and i put miles on it and two because it still has dual point. and ive read that fixing up a D series isnt worth it my money is limited and im not sure were to start i want to fix up D series but not sure exactly if its worth it..
Old Jul 17, 2013 | 03:33 AM
99teggsr's Avatar
That all depends on your goals with said engine.
Old Jul 17, 2013 | 01:57 PM
ok i pretty much just got the 91 si the engine and tranny is pretty much better than mine so right now im guna swap them. and i want my car to ride good and be able to keep up you know if they wanna mess around i at;east have sumthing that can keep up and not make my car look dumb i wanna cherry it out and have it run good. and thanks for replying
Old Jul 17, 2013 | 02:10 PM
radex7's Avatar
Who are they? Zee Germans? Anyway, 91 Si is a nice and easy upgrade. It looks like you will be running it with AEM cold air intake, and non-OEM header - great! First things first, though: you need to convert to MPFI and swap ECU from stock to PM6. FAQ has a ton of info on this process. Good luck.
Old Jul 17, 2013 | 04:59 PM
ha what i meant by ''they'' is the other guys in my area that drive hondas but most likley my cousin bc he has a 91 si zc with high compression..its pretty quick so im just trying to get mine to run good. and ok when u say to swap to mpfi im sure that means not to use my dual point that i have in my 90 bc the si is mpfi i heard dual is pretty gay and i drove the si and it runs a whole lot better then my 90
Old Jul 22, 2013 | 03:35 PM
turn&burn89's Avatar
you have to either swap the ecu for a different one like the other guy said or rewire your existing ecu to run MPFI, the dual point has 2 injectors and MP has 4 so the computer needs to be able to run 4 injectors after the swap. but yea intake, headers and maybe a new cat, catalytic converters manufactured now are naturally ''higher-flowing'' then your, most likely, original cat. but other then that you can run z6 cams, i think & w/ a new dizzy, and mill your head and use a multi-layer steel head gasket for higher compression. but a D series is only a D series without a lot of building.
Old Jul 24, 2013 | 01:31 PM
Ok cool thanks and I have the Ecu for the swap from the si so are you saying that after u put the other engine in that I cnt just plug in the Ecu I wuld have to wire it? And as far as higher compression how wuld I do that? Can you give me links or help out a Lil bit thanks
Old Jul 24, 2013 | 01:36 PM
And can you tel me were i would be able to get some parts and if I cam it would i e able to just can it or wuld I have to get other stuff to it wuld be able to handle me caming it?...
Old Jul 24, 2013 | 03:09 PM
radex7's Avatar
I don't want to sound rude, but maybe you should get the MPFI swap figured out first. Get it running, tune it up well, see how it feels. This is a perfect start. Once you decide it is not enough - put that D16A6 in, have fun with it. Still not enough oomph? Now consider Naturally Aspirated build, or turbo, or B-series or higher, or whatever rocks your boat.
Do you already have the tools to do everything you want now? Did you also consider the amount of money you will have to invest? I hate to say it but you are behind on your research, and it shows.
I do say these things sincerely, I am not trying to offend or upset you.
Here are your parts sources. We all shop in the same places.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/%24-sale-want-buy%24-88-91-crx-civic-parts-only-no-comments-allowed-3116205/
http://fresno.craigslist.org/pta/
http://www.ebay.com/
http://estore.honda.com/honda/
http://www.picknpull.com/
Old Jul 26, 2013 | 08:59 PM
no i get it and ya i have all the tools and wat im trying to do is just basically take my d15 out and put the d16 in it has everything wire harness injectors manifold all that i knw dual is two injectors bc thats what i have now. i have some after market parts to help but when i got my car the engine was a lil worn out i just wanna put the 16 in and just fix that one up and ya i have price checked i knw it shows that im behind on my research but thats why i got on here to try and find help and to learn more i mean i dont just wanna buy parts put them in and mess up the engine thats why i said im still learning. i mean if you could help out with some honest info links anything that can help[ i would really appreciate it. thanks for posting though
Jake Pwns Hard
20
Dec 4, 2008 07:37 PM
rollinonblades
Jun 7, 2008 08:33 PM
nomotor
Apr 25, 2004 12:36 AM
VashTheStampede
May 22, 2003 12:55 PM
northernvermonter
Apr 4, 2002 12:00 PM
