Can 14" steel rim fit on itr?
Old Oct 24, 2002 | 05:18 PM
itr1244's Avatar
Default Can 14" steel rim fit on itr?
is the caliper clear?
any idea?
i want to put winter tires and i got 4 tires for 100 CAD(USED) also free mounting
and now i think i made mistake. i have feeling that there will be no 14" that will fit
help please
thx
Old Oct 24, 2002 | 05:19 PM
Jin Yamato's Avatar
Default Re: Can 14" steel rim fit on itr? (itr1244)
Probably shold fit, it is doesnt you could always sand the caliphers down a bit
Old Oct 24, 2002 | 05:20 PM
itr1244's Avatar
Default Re: Can 14" steel rim fit on itr? (jin_)
Really?
damn~ that must be alot of work
Old Oct 24, 2002 | 05:21 PM
Champ R's Avatar
I dont think it will, if you look at the 15" wheels the calipers are nearly touching in the front.
Old Oct 24, 2002 | 05:24 PM
ZygSpeed's Avatar
Default Re: Can 14" steel rim fit on itr? (Champ R)
Are they even 5 - lug?
Old Oct 24, 2002 | 05:28 PM
itr1244's Avatar
anybody know the full bolt pattern for r?
i know it's 5 *114 something~
can someone tell me
Old Oct 24, 2002 | 05:30 PM
itr1244's Avatar
Default Re: Can 14" steel rim fit on itr? (Zygspeed)
actually i went to walmart and bought a set of 14" steel rim without thinking~
i bought it and they are 5 luggers~ bolt pattern 5*114.3
but it didnt fit~
what pattern do i have to get?
anyone know if there is any rims that are 14" and 5 lugged?
thx
Old Oct 24, 2002 | 05:36 PM
nsxtcjr's Avatar
New User
The specs on the ITR rims are 50 mm offset, 15"x6", center bore 64 mm, bolt pattern 5 x 114.3.
Ever wonder why they chose 114.3 mm as the diameter of the bolt circle? Because it's exactly 4 1/2 inches.
You'll need 15" rims. You can buy steel rims at the Tire Rack. If you buy your winter tires and rims as a package there, you won't have to pay anything for mounting and balancing.
Remember that the stock lug nuts have a spherical (acorn) seating surface. Either (a) make sure the steel rims also have a spherical (acorn) seating surface, or (b) if you get steel rims with a conical (tapered) seating surface, you'll need to also get a set of lug nuts to match.
Old Oct 24, 2002 | 06:00 PM
itr1244's Avatar
Default Re: Can 14" steel rim fit on itr? (nsxtcjr)
thx for the help man~
Old Oct 24, 2002 | 06:23 PM
Mr Hammond's Avatar
a/k/a Jomo
HMMM that's tought. Jamie where you at? He fit HX wheels on a 92 hatch with GSR brakes w/ some sanding. Don't know if this helps.
[Modified by Mr Milano, 10:23 PM 10/24/2002]
Old Oct 24, 2002 | 07:18 PM
Unlimited's Avatar
New User
Default Re: Can 14" steel rim fit on itr? (Mr Milano)
since 14" rims will fit on itr i'm going to be the first to use 13" rims from now on pardy hardy yo
dc4g
Honda Fit
Jul 21, 2006 01:04 PM
HaleLude
Jun 18, 2003 04:30 AM
Dave-ROR
Nov 4, 2002 09:21 AM
Brian
May 1, 2002 01:27 AM
98R-1144
Feb 11, 2002 10:53 AM
