Weird idle/ accleration
Hey guys, i just did my lsv in my eg with gsr head with blox intake manifold. Im using the ls throttle body and when i first start it, it is fine than if you keep on driving it for a couple of minutes you cant accelerate and if you do the rpm goes down. Than turn it off and back on again it runs fine again but the idle goes really down like it go so down than that the engine die. I got to keep reving it to not make it idle down. So guys what you think is the problem and i need it fix ASAP
First things I'd check (probably in this order too). Not a lot of info so you may have done these already. Check google for threads of people trouble-shooting with these parts for more information.
I'm guessing no CEL's....?
TPS
MAP
IACV
Vacuum Leaks
Cap/Rotor/Plugs/Wires
TPS
MAP
IACV
Vacuum Leaks
4gen
Jan 11, 2004 05:28 PM
