RPM Jumping randomly
Old Jul 16, 2013 | 11:04 AM
dafreeeze's Avatar
Default RPM Jumping randomly
Was driving home from work and its about 40 degrees here in toronto with humidity and sometimes when coming to a stop sign or red light i put it in neutral and the car stays at 2000rpm for about four or five seconds before it drops down to 700rpm what could be cauaing this? IIm running a b16a2 in a 93 eg coupe
Old Jul 16, 2013 | 11:15 AM
Former User's Avatar
Default Re: RPM Jumping randomly
Try cleaning the IACV.
Old Jul 16, 2013 | 12:05 PM
dafreeeze's Avatar
Hey ron, i just cleaned it the weeks ago do you think it would be gunked up that quick? And when i cleaned it, it wasnt that bad at all i could see through the mesh
Old Jul 16, 2013 | 12:08 PM
dafreeeze's Avatar
Could the throttle plate perhaps be sticking open? If so what would you use to clean it? Regular degreaser?
Any CEL codes?
Does the throttle body have an FITV?
Have you bleed the cooling system?
Have you adjusted the idle speed as per the service manual procedure?
Old Jul 16, 2013 | 12:09 PM
Yes. Clean the throttle body with carburetor or brake cleaner and make sure that the throttle cable is properly adjusted to have some slack.
Old Jul 16, 2013 | 12:13 PM
dafreeeze's Avatar
No codes thrown, cleaned fitv during the iacv cleaning, bled the system
No i didnt adjust idle speed its staying at 750-800 range. Ahhh alright i will adjust the throttle cable i recently tightenes it a bit a didnt know it needed slack i though the throttle cable maybe got worn over time so i tightened it
Old Jul 16, 2013 | 12:16 PM
Old Jul 16, 2013 | 12:27 PM
dafreeeze's Avatar
Sorry ron but cable deflection, i cant really tell what its saying. It has to be 10-12mm from what?
Old Jul 16, 2013 | 12:30 PM
At the point in the cable indicated in the diagram, you should be able deflect/move the cable 3/8" to 1/2" from center. In other words, there should be 3/8" to 1/2" of free play in the cable - cable movement that would not open the throttle plate.
Old Jul 16, 2013 | 12:37 PM
dafreeeze's Avatar
And why would a tighter throttle cable be a bad thing? Just wondering
Old Jul 16, 2013 | 12:40 PM
A tight cable might prevent or slow the throttle plate from closing fully.
Old Jul 16, 2013 | 12:42 PM
dafreeeze's Avatar
Ahh makes sense, off to clean the throttle and adjust the cable. Thanks alot man i appreciate your time
Old Jul 16, 2013 | 12:43 PM
Old Jul 17, 2013 | 04:47 PM
dumplingz's Avatar
sticky throttle cable, tps or computer.
Old Jul 17, 2013 | 05:06 PM
dafreeeze's Avatar
Throttle plate was binding ended up being the culprit. I guess the hot weather made the gunk in the throttle body sticky so i cleaned it out as far in as i could reach. Works fine now, no jumping rpm.
Kman1371
Feb 14, 2017 08:22 AM
Gemar
16
Apr 11, 2013 07:58 PM
sevenfc
Mar 23, 2009 02:38 PM
supracrx
Jan 7, 2007 08:06 PM
1QWKGS
Apr 3, 2005 11:52 PM
