P28 throwing CEL but disappears when ignition is turned off.
Old Jul 16, 2013 | 06:19 AM
SHG_Claudio's Avatar
Icon6 P28 throwing CEL but disappears when ignition is turned off.
Hey there guys, I've been having a CEL pop up on my D16Z6 when either:
1. Highway cruising after a while of driving
2. Revving through the RPM range usually done at WOT. Throws it in the high rev range (i.e 6,000-7000rpm)
It stays on until I turn off the ignition which it then goes away meaning I can't pull the code from the ECU to know what it is.
Any ideas as to what it could be or why the ECU isn't storing the code? I've replaced the backup and ECU fuse in the under hold fuse box for certainty even though they were both good yet it still doesn't store the code.
The car is pulling strong but has a bit of a funky idle sometimes if that helps anything.
Any help is appreciated!
Old Jul 17, 2013 | 10:02 PM
swordofdoom's Avatar
Default Re: P28 throwing CEL but disappears when ignition is turned off.
Chipped ECU or stock>?
Old Jul 18, 2013 | 05:31 AM
Chipped unfortunately. Bought it like that. Probably an eBay chip or something. I'm planning on picking up a S300 in a couple of weeks.
Old Jul 18, 2013 | 04:22 PM
Prob missing something in the tune, I would check the chip over and make sure the settings are correct. More than likely it may have something to do with vtec
Old Jul 18, 2013 | 04:26 PM
I have a feeling that its the o2 sensor saying its lean/rich but I'll find out soon enough. Thanks so far for the help.
Old Jul 18, 2013 | 08:04 PM
mtber's Avatar
Answer is simple: Drive the vehicle until the codes are thrown and leave the engine running when you check the codes.
For instructions on how to check your codes go to http://www.phearable.net/tech
killaberna
Jan 16, 2013 08:09 PM
acuracy r
Jan 3, 2006 05:56 PM
UNKNOWN_MEMBER
Jun 9, 2005 08:09 AM
racekar
Sep 21, 2004 04:42 PM
4drGSR
Feb 23, 2002 10:53 PM
