getting the most out of my d16z6
Old Jul 15, 2013 | 07:58 PM
delsoldriver96's Avatar
Default getting the most out of my d16z6
Anyone know how I can get any extra power out of my Honda del sol si with a 1.6 liter d16z6 vtech ??? I have headers and a cold air intake installed
Old Jul 16, 2013 | 05:35 AM
SHG_Claudio's Avatar
Default Re: getting the most out of my d16z6
Do some maintenance and it will run better. OEM NGK spark plugs, spark plug wire set, distributor cap + rotor, clean the injector baskets and check the distributor ignition timing to see if its where it should be. Once your maintenance is up to par you could benefit from a Hondata S300 and get it tuned. Gains with the Z6 will be hard to achieve without forced induction so while staying NA you could get some aftermarket camshafts + cam gear but what you spend will not be very rewarding power wise. I say just make sure the motor is running good and save for a swap.
Old Jul 16, 2013 | 07:52 AM
Thanks for the tip man! I'm thinking about saving up to do a b22 swap in it
Old Jul 16, 2013 | 07:53 AM
What's a B22?
Old Jul 16, 2013 | 08:39 AM
Not a b22 a b19a2 I think its somethin like that its an Integra motor what would you sugest I do for a swap
Old Jul 16, 2013 | 08:44 AM
There's no such thing as a B22 or a B19a2. Maybe you shouldn't swap anything until you know what you're doing. I suggest any variation of a B16 but that's preference because everyone will go their own route so my suggestion has no substance for you.
Old Jul 16, 2013 | 10:06 AM
H22 not a b22 sorry man
Old Jul 24, 2013 | 09:18 AM
8993civtegraSI's Avatar
H22 requires alot of work... Is a great mltor if your willing to take the time and do it right... I intend to do a b16 swap in my 89 civic... Im lazy to lazy to do the extra work so im sticking with b16 or 18 for sure
Caylen Klassen
Feb 21, 2016 04:52 PM
tundra2000
Jun 8, 2010 03:27 PM
jdmstockeg6
21
Sep 4, 2007 11:22 AM
EF_yo_89
Jul 6, 2004 12:23 PM
