Can't get Clear Coat Glossy
So I ordered a kit from paintscratch.com. it was the primer, base, clear, and rubbing compound
i followed their directions and buffed the clear with a buffer and this is the end result
idk what to do at this point. that was 5 coats of base and 4 coats of clear. should i wet sand it then try to buff it again?
no, thats one of the questions i asked, should i wet sand this new clear, then buff again. and what grit should i use? 1000? 1500?
You will need to wet sand, get 1500, 2000 grit sand paper, make sure to use plenty of water. Then go to your buffer, Only problem with clear coat from a can is most times its a 1 part clear and they usally fail pretty quick. Also it has a ton of texture so you sprayed it on to dry.
1500-2000/2500 and then buff/polish it.
Make sure you use quality paper, 3m, meguiars, etc and a backing pad. Use plenty of water and clean the paper off from time to time...
