CO - 1994 Civic EJ1 EX Coupe JDM K20A Red
Old Jul 15, 2013 | 03:39 PM
Quik Chris's Avatar
Default CO - 1994 Civic EJ1 EX Coupe JDM K20A Red
FS: 1994 Honda Civic EX Coupe
1HGEJ1123RL003383
Asking: $9,750
Car is located in South Metro Denver area and available to test drive.
212,000 miles on Body. Body purchased in 2006 completely stock, black, with front end damage. Purchased all OEM Honda parts necessary for fixing all damage including radiator support, fenders, hood, bumper, bumper cover, emblems/badges (front/rear), all side black trim surrounding windows, antenna, car repainted (R-94) San Marino Red (from Accord Coupe) engine bay, trunk and doorjams all painted with absolutely zero flaws or oversprays. Body work done by same individual who does all body work for Ferrari of Denver dealership.
http://i81.photobucket.com/albums/j2...ivmirror-2.jpg
  • 2004 DC5 Type R JDM K20A full swap purchased last fall from Hmotorsonline complete with OEM 6 Speed LSD Transmission
  • Hasport street K-Series Mounts
  • Hondata KPro Professionally tuned at Importsports Performance in Denver, car put down 196 whp in Denver (5,600 ft)
  • Holley EFI black fuel pressure regulator w/ liquid filled gauge
  • Black Golden Eagle
  • K-Tuned Ram Horn Header
  • Hybrid Racing Cold Air Intake
  • Custom built 3" mandrel bent exhaust with test pipe / Black 3" Vibrant Muffler and 40" Resonator
  • Hybrid Racing Swap shifter with Momo Superanitomico shift ****
  • Sparco flat bottom steering wheel with removable hub and hub lock
  • Hybrid Racing hydraulic clutch line
  • DSS Stage 0 swap axles
  • Competition Clutch Stage 3 Clutch
  • Hybrid Racing Swap Aluminum Radiator w/ Flex-a-lite Fan
  • Hybrid Racing power steering kit (not currently installed)
  • TEIN Flex full coilover suspension
  • Suspension Techniques urethane bushing kit--only 2 installed, intended for use with DC2 disc brake trailing arms, included but not installed
  • Sprint Hart CP-R wheels 15 x 7 +38mm offset with Falken Azenis 205/50/15 Tires
  • Vision carbon fiber side mirrors
  • OEM JDM Civic headlights / clear corners
  • ARP front extended wheel studs
Known issues:
  • Ram horn header interferes with heater core hoses, heater is disconnected
  • Hood needs replacement. When installing the power steering, I tried to close the hood, the pulley dented the underside of the hood after cutting the skeleton out. Out of frustration, I cut a hole in the hood so the P/S would fit (since it was ruined anyway). There is a sticker covering the hole now. Ghetto I know, but hey, I was frustrated. A Jackson racing PS pulley would allow for proper hood clearance.
  • Coilovers are raised in the front currently to fit 24.5" Slicks
  • Windsheild washer fluid lines need a "Y" part to allow the washer to work.
  • Brake master cylinder may need to be replaced.
  • 96 Civic Radio doesn't fit in dash.
  • Speedometer and Tachometer in Hondata needs to be calibrated using a dyno.
  • Moonroof opens and closes, but needs to be greased.
  • Back trim around windsheild not currently installed
Quik Chris
Sep 12, 2013 11:59 AM
99ssinoc
Texas -OK -LA (Sales)
Mar 19, 2009 08:55 AM
wasssup
59
May 6, 2008 04:44 PM
gsp ej1-em1
Northern California (Sales)
28
Nov 9, 2006 07:18 PM
BLUTO
Oct 23, 2004 10:43 AM
