how to clean battery terminals ??
Old Oct 24, 2002 | 04:47 PM
BlackCRX's Avatar
Default how to clean battery terminals ??
i did a search already but didnt come up with anything
my battery terminals have that powder stuff on it now and i was just wondering how to clean it
i heard pouring a can of coke can bubble away the acids, is this true ??
any suggestions will be appreciated
Old Oct 24, 2002 | 04:52 PM
Redline130's Avatar
Default Re: how to clean battery terminals ?? (BlackCRX)
I just use a wire brush or my dremel to clean out the corrosion on my batteries.
Old Oct 24, 2002 | 04:56 PM
mr. carpenter's Avatar
yes this is true. after you do that wipe away the excess w/ a old rag , the corrosion may eat the rag some. also it would be good to get a post and terminal cleaner which is basically a wire brush that you can put over the post and turn. you want a good shiny contact area on the post and the terminal.
Old Oct 24, 2002 | 05:02 PM
BlackCRX's Avatar
Default Re: how to clean battery terminals ?? (mr. carpenter)
you mean using coke right ??
should i just remove the terminal and pour a little coke on it or should i take the whole battery out and do it ??
is there anything i can do to prevent it from comming back ??
Old Oct 24, 2002 | 05:15 PM
shorti's Avatar
grab a squirt bottle and fill it with water. add some baking soda and shake. squirt on the terminals. let the stuff do it's work and then rinse off the crap with regular water. done
Old Oct 24, 2002 | 05:48 PM
just pour it straight out of the can on there, not alot of course. you just need to nuetralize the acid w/a base so you can wipe it off in a non corrosive state the baking soda works perfect also. don't take the battery out. i'm not sure how to stop it ? i just periodically clean mine when i'm working on the car.
[Modified by mr. carpenter, 2:51 AM 10/25/2002]
[Modified by mr. carpenter, 2:53 AM 10/25/2002]
Old Oct 24, 2002 | 06:23 PM
raene's Avatar
I hear you can coat it with vaseline to prevent oxidation. But mehhh...
Old Oct 24, 2002 | 07:12 PM
Home Skillet's Avatar
Default Re: how to clean battery terminals ?? (raene)
easiest way to do it is with Coke.
Old Oct 24, 2002 | 07:42 PM
altoid's Avatar
Default Re: how to clean battery terminals ?? (Home Skillet)
dudes! what an awesome topic, im so doing that with coke this weekend!!!
Old Oct 24, 2002 | 09:21 PM
MisterB's Avatar
Default Re: how to clean battery terminals ?? (altoid)
i use baking soda with water works good for me just let the acid neutralize then wash it off... never tried the coke thing but it makes sence
Aseegz
Jul 18, 2013 12:34 PM
NewfieAccordEXR
Feb 4, 2006 07:07 AM
david90
Aug 16, 2004 05:06 PM
lke2drvgsr
Dec 5, 2003 01:57 AM
94TealGSR
Nov 8, 2002 11:36 AM
