why flickering batt light?
91 civic dx , d15b, no codes
so two days ago my batt light starts flickering on and off
die hard batt, napa alt, both around 6 months old
batt was 80%, charged it to 100%
i have 12.4v across posts with engine off
start car, still 12.4v , turn on lights, alt kicks on, 14.1v
so why would the light be flickering on and off?
batt was 80% from 6 months of use
i bought a napa cuz i heard they are almost as good as oe
i'd never buy an autozone or advance
so why would batt posts say 12.4 when car running, then 14.1 when i turn on the headlights?
another symptom is, it never comes on when the car is sitting still
only when i'm driving it, and usually when coming to a stop
can't seem to find any loose grounds tho
Remove the alternator and have it bench tested. Advance seems to have the better of the testers, at least around here. Most of your parts houses gets their alternators from the same provider, and nearly all batteries are made in Mexico now (including Optima's).
It sounds like your alt or ELD is bad, leaning toward your alternator though.
eld? would that throw a code?
when the alt went bad in march the light never came on,lol
once i see the radio turning off by itself i know i'm fed
if the light doesn't come on when alt is bad, and flickers now, perhaps it's acting faulty?
like everyone said check your grounds/connections and dont rule out the possibility that your alternator may be going out. in my case my car does the same thing because of a loose alternator belt as a result of me being too lazy to tighten it properly and my batt light will flicker when starting on cold days or revving too quickly with a cold engine. so check your belts condition and clean the pulleys with degreaser.
It may not hurt either to check all your connections. under dash, at fuse box, in engine bay. Just start unplugging connectors and plugging them back in till you hear the connector tab click. after 20 years its not hard to imagin a connector getting a little loose or dirty.
Fixed my intermittant head unit this way.
When I had problems occuring while stepping on brakes it was the ICU. moving the brake caused the fuse box to flex enough and start shorting stuff inside the ICU. It couldnt hurt to pop that off and check the inside for burnt components and traces.
Im only suggesting this because you still have yet to follow everyone elses suggestions and check your battery and charging system.
"batt is fine, i would have to pull alt to have it tested, not in 95 degrees i'm not , belt is good"
Or you could goto harbor freight and get a $4 digital Multimeter
So how did you fix it ??? It just fixed itself ?
yep, not doing it now, got me, problem with cars this old, electrical issues can be hard to nail down
well, this seems to be happening not with every ignition series
meaning, i can turn the key and drive and get nothing, but, i may turn the key and get the flickering, if it's nothing it stays nothing
not only flickering, but fading on and off as well
seems to me it is a connection somewhere , but all the grounds in engine bay seem fine
any guesses?
any guesses?
chadtheman
Honda Civic (2001 - 2005)
Jan 24, 2013 12:24 PM
JDM DERF
Jan 27, 2005 07:50 AM
