Specific speedometer issue
My speedo on 97 DX works about 5% of the time, and even then it is still fluttering. Otherwise, it is fluttering, flipping back and forth, or dead needle. The odometer and trip work fine as well. Now, I know this is a common issue, but I have researched and addressed the problem with tact. I changed the circuit board on the back of the gauge, cleaned vss plug, checked appropriate fuse, etc. No results.
However, when I drive, and it flutters, it responds to other electrical devices. I.e., it will move or stop when I mess with the AC and/or fan speeds.
Side note: the car has no stereo and that harness has been cut.
My question is this: This is obviously an electrical problem, however given the details I have given you is this a specific problem with a specific solution? Or just a general short somewhere. Also, is there anywhere you recommend that I look? Perhaps where the stereo harness was cut?
Please and thank you, internet.
I had a similar problem. Sputtering needle, sometimes it would work and sometimes it ll be completely dead. Ordered a used vss from Hmotors for cheap and all is good. It took five minutes to replace.
All resolved. Changed speedo, which was procured from a junkyard.
FYI: if you want to pay less to fix the speedo, take apart the gauge cluster in the yard and just buy the loose speedometer gauge; cost a fraction of the price compared to an entire cluster.
Thanks.
Thanks.
Fantastic420
Sep 25, 2009 08:08 PM
