Cigarette lighter doesn't work
New User
Hey my cigarette lighter doesn't work in my EG. I checked the fuse to see if it was burned but it wasn't. What else can be the problem? Thanks...
Re: Cigarette lighter doesn't work (Si HaTcHBaCK)
check to make sure the harness is plugged in behind the lighter.
also see if you can get 12v out of the lighter now, maybe what you are trying to plug into it doesnt work.
New User
Re: Cigarette lighter doesn't work (tonyxcom)
Well I did a couple of tests on it today like, when i push the cigarette lighter in, it doesn't stay down like it suppose to. But when I put the cell phone adapter in it works perfectly and charges my phone. What the hell is wrong wit it???????????
Not sure how you can fix it, since I have never bothered to fix that problem when I came across it in my old car. I usually just broke out the bic, and if I didnt have one, I just held the cigarette lighter pushed in for a few seconds to heat it up.
Location: Where All Funky Things Come From...., Stankonia, USA
Re: Cigarette lighter doesn't work (poison)
if your cell phone adapter is working, then it's your cig lighter.
New User
Heres the thing I push the cigarette lighter down it still doesn't light up? Well maybe Im not pushin it down long enough i dunno But I just want my things in my car to run right. O well thanks for all ur help, tonyxcom
no problem..
if after 10 seconds the lighter isnt hot, then your lighter is definetly bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si HaTcHBaCK »</TD></TR><TR><TD CLASS="quote"> I checked the fuse to see if it was burned but it wasn't. </TD></TR></TABLE>
Where is the fuse located for the 12v power supply 96 Cx?
Car charger works in Accord, but not my EK. Panels are pulled to make sure it's plugged in
