Eg/ej cluster help !
Old Jul 13, 2013 | 02:59 PM
Achroth's Avatar
Default Eg/ej cluster help !
Hey guys I swapped out my dx cluster last night for an ex cluster seemed to work fine and I opened it and installed LEDs and put it all back together and now everytime I turn on the switch the temp needle will shoot all the way up and stay there even after I press it down with my finger. I swapped back to my old cluster to check if my temp was actually that high but no car is normal .
Any info on how to fix this or maybe I put it back wrong or do I have to get a new gas/ temp gauge ?
Thanks!
Old Jul 13, 2013 | 04:56 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Eg/ej cluster help !
Why did you have to open it up? Did you just not use LED bulbs?
You messed up something obviously. Take the cluster back out. Recheck your work.
Old Jul 13, 2013 | 05:37 PM
NVturbo's Avatar
O.G. triple O.G.
the temp gauge is bad. That gauge can be purchased from Honda for around $60 or so. For that much, you're better off getting another used cluster.
Old Jul 13, 2013 | 05:54 PM
Achroth's Avatar
Nope used led strips . Couldn't find the bulbs . What could have gone wrong though ?
Old Jul 13, 2013 | 05:55 PM
Achroth's Avatar
Yeah no way on me messing it up is there ? Yeah I bought the cluster for 70$ :/
B_Swapped93's Avatar
it's more likely that OP messed up while installing LED's....
led strips instead of bulbs how does that work ? is this some custom project ?
Old Jul 13, 2013 | 06:01 PM
Moms 94's Avatar
Led bulbs at Autolumination
Old Jul 13, 2013 | 06:07 PM
Achroth's Avatar
That's what I'm trying to figure out if it was me then how could I have done it since its basically just unscrew 3 screws and that's it it's off . Tryin to fix it if it was me by any chance but doubt it .
Yeah custom project .
Old Jul 13, 2013 | 06:08 PM
NVturbo's Avatar
O.G. triple O.G.
^^^ if your old cluster works fine and the new one has an issue with the temp.....IT'S THE GAUGE. Too bad you can't swap one onto the other.
Old Jul 13, 2013 | 06:17 PM
Achroth's Avatar
Yeah thought so I thought I might have messed up on putting it back so I had hope I could fix it .
Junkyard time !
Ty h2b eg
Jan 27, 2018 10:22 AM
MTarry
11
Jan 15, 2013 06:46 PM
twedter02
Sep 24, 2010 10:00 PM
95LStizzy
Jan 3, 2006 03:12 PM
