f20b5 distributor ignition
Old Jul 13, 2013 | 12:46 PM
carzIL's Avatar
Icon6 f20b5 distributor ignition
hi
I want to know to break the distributor ignition of f20b5 engine into pieces. If you have a video or instruction I would be very happy.
Thanks. Honda accord 2001 build in japan...if it matters.
Old Jul 14, 2013 | 12:10 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: f20b5 distributor ignition
This may be helpful... https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-internal-seal-distributor-internal-oil-leak-2214402/
Old Jul 14, 2013 | 09:01 AM
carzIL's Avatar
Thanks, but its not the same as mine. I'm uploading some images, maybe you can understand how to open it.
Old Jul 14, 2013 | 11:03 AM
MAD_MIKE's Avatar
MM Gruppe B
Second image in that link is of this...
It is similar.
Old Jul 14, 2013 | 01:42 PM
carzIL's Avatar
Thanks,
But as you can see in my pic, the PIN is locked in different way. I cant find a way to remove it.
Old Jul 14, 2013 | 10:17 PM
carzIL's Avatar
I asked http://www.youtube.com/user/Bushougoma for an answer to my question. He told me:
That pin is in interference fit you'll need a flat punch just the right size to fit over the pin but not bind up in the hole and a big hammer to drive it out.
Start with a standard ball peen and go up to a 3 lb mini sledge if it's being stubborn.
Just be sure to support the end of shaft with a piece of wood while striking to protect the bearings.
Sent to: Idan Shem Tov
I'll tell you if it works
Jeul
Jan 13, 2010 04:12 AM
wesk18
Sep 30, 2009 04:14 PM
kkilo
May 5, 2008 01:09 PM
greengiant
Jun 15, 2006 05:04 AM
nitemarez
Mar 5, 2004 04:17 AM
