Sfwd/ true street part out 900hp
Pte 6766 1.32ar 900
Afi forward facing dual 38s 800
Victor x gsr powder coated 250
Competition twin disc 800
1600 cc injectors 200
Welds 13x10 24.6/9/13 950
Exospeed coated black centers skinnes star 8 with tiers 950
Aem v1 obd2b with wireworx harness and m&m pro14 with t1 trigger kit with both cam gears 1800 it's ready for a stwich panel with all relays
Erl gsr 83mm long block
Cp pistons flat tops 9:7:1
Manly turbo tuff rods
Gsr crank
Acl race bearings
Fluidamper pully
Gsr oil pump oem
Arp main studs
Head gsr
Port and polish
Ferrera 6000 valves std
Golden eagle head studs
Golden eagle head gasket
Skunk2 pro1 cams (vtec locked)
Golden eagle cam gears
Gates timing belt
Oem water pump
T1 cam seal
T1 vtec delete plate
Back valve cover with breather
Everything is brand new in the motor other then cam gears and damper pully
$5.300
. All parts In the long block are new call or text me for more info 239-398-7098
https://honda-tech.com/forums/showth...66+ture+street
There's all that parts that are for sell even the shell with the for 1600
Gsr crank
Acl race bearings
Fluidamper pully
Gsr oil pump oem
Arp main studs
Head gsr
Port and polish
Gates timing belt
Oem water pump
T1 cam seal
$5.300
. All parts In the long block are new call or text me for more info 239-398-7098https://honda-tech.com/forums/showth...66+ture+street
Pte 6766 1.32ar 900
Gsr crank
Acl race bearings
Fluidamper pully
Gsr oil pump oem
Arp main studs
Head gsr
Port and polish
Gates timing belt
Oem water pump
T1 cam seal
$5.300
Gsr crank
Acl race bearings
Fluidamper pully
Gsr oil pump oem
Arp main studs
Head gsr
Port and polish
Gates timing belt
Oem water pump
T1 cam seal
$5.300
CDP
Feb 10, 2007 02:33 PM
