b16a first gen problems staying on\//////
Old Jul 12, 2013 | 02:53 PM
TypeR snooze's Avatar
Default b16a first gen problems staying on\//////
so i have a 91 b16a engine that i bought online turned outt fine it has 170 on all cylinders. but im having a problem with it staying ON. it ***** off after 2 sec. i swapped sensors from my b16a2 to my b16a. the tranny is from my b16a2. so i have installed a obd2a harness witha obd2b ecu. everything plugs up i have fuel i have spark it turns over but immediately shuts off. can sumone help me out. oh yea all this is in a ek9
Old Jul 12, 2013 | 03:44 PM
swordofdoom's Avatar
Default Re: b16a first gen problems staying on\//////
Perhaps you should read the codes and find out what exactly is not working. What OBD dizzy are you using? OBD0 dizzy does not work with OBD1 and 2 ECU. Your timing could be off. You could be missing other sensors or they are not plugged in correctly.
Old Jul 12, 2013 | 04:46 PM
Crxcam's Avatar
I had this problem it was just throttle screw needed adjusting it was all the way shut
Old Jul 12, 2013 | 06:15 PM
BrightBlueBeast's Avatar
Did you check fuel/vacuum lines? I left a vacuum line off of the back of the intake one time.
Because there are so many lines and wires around the engine, you may have missed one that became shoved or placed out of the way. I always go around the engine components to see if I missed anything. Oftentimes, I have.
Old Jul 12, 2013 | 08:00 PM
ill recheck the vacuum line but im pretty sure i got those connected. im not getting any engine codes. timing is not off i checked that already. now the throttle screw is something that i wanna check cuz i did take out the throttle body to clean it up before i installed it again. but there is a sensor in the back thermo fan switch not connected i dont have a plug on the harness that fit that. im using the thermostat from my b16a2 that has the same sensor on it that one plugs in fine. im using a obd1 distributor with a obd2 to a obd1 dizzy adapter.
Old Jul 12, 2013 | 08:33 PM
category5's Avatar
You mentioned the use of an obd2b ecu, have you removed or disabled the immobilizer?
Old Jul 12, 2013 | 08:38 PM
i dont know how to do that?????????
Old Jul 12, 2013 | 08:48 PM
its a pt2 it doesnt come with immobilizer
Old Jul 12, 2013 | 08:51 PM
category5's Avatar
gotcha, and the fuel pressure is steady?
Old Jul 13, 2013 | 09:50 AM
yea stays between 35- 40
6kdropout
May 4, 2013 07:23 AM
t3gav
Dec 12, 2011 07:16 AM
AKAViRiZ
Apr 28, 2010 10:30 AM
howangseg
10
Jun 20, 2007 02:19 AM
91sifreak
Jul 17, 2001 06:15 PM
