89 accord timing help needed!
Hi guys im new to the forum but not new to honda's, just bought a 1989 accord with the a20a4 engine, it has i think an iginion timing issue, the idle is quite lumpy. From what i know the disburtor was changed a couple of years back but not done properly, Does the rotor arm need to be adjusted or is there a bolt on the inlet/carb that will sort it ?
Cheers michael.
Cheers michael.
Try posting your symptoms over at www.3geez.com. They should be able to help you.
jrzep
May 9, 2014 07:20 AM
toledorocks
Nov 17, 2003 12:17 PM
