My oil feed line size, help
Old Jul 12, 2013 | 11:50 AM
Ram2012's Avatar
Default My oil feed line size, help
I have a t3/t4 .48 trim turbo and im having a problem with it burning oil, i need to find out what size feed i have because i have no idea what it is.
How do i measure what -Xan it is?
also someone told me to use a -3an size feed line, and should i get a restrictor
Old Jul 13, 2013 | 11:38 AM
Ram2012's Avatar
Default Re: My oil feed line size, help
anyone please help
Old Jul 13, 2013 | 12:36 PM
Turbo-LS's Avatar
if its a journal bearing turbo and your seeing oil pressure about 65 psi at any time then yes you should run a .065 restrictor. If its ball bearing you should be running a .035 reguardless or what oil pressure your car has.
Old Jul 13, 2013 | 12:40 PM
Orangevirus1's Avatar
what's a T3/T4?
4AN feed line.
your problem probly isn't your feed line.
the problem probably is that the turbo is a cheap fake.
bigdgsr
Sep 21, 2009 08:33 AM
oz`Vtec
Jun 9, 2004 07:26 AM
Carp
May 8, 2003 04:29 PM
B20-T
Feb 12, 2003 03:04 PM
pagong
Feb 6, 2002 07:52 PM
