Noob to this forum but not to honda
I have a 1999 lx civic i have been building for years. I have over 5000 in the d16y7 producing over 300 hp at any given time. I have H beam rods, 76mm low comp pistons, adjustable fuel regulator, 38mm external wastegate, ported and polished log manifold, hks blow off valve, 2.5" intercooler system, aluminum radiator, ex intake swap, chipped p28 ecu, obd2 to obd1 converter, 3" full turbo exhaust system, factory cam with adjustable cam gear, port and polish, ID 1000cc injectors, 93 or better gas, 15 psi stable, s20 transmission swap from 93 civic with LSD, short throw shifter, coilover suspension with adjustable upper front and adjustable rear upper, aluminum lower control arms, sitting on Enkei rs6 rims.
I built this car from the ground up. It has been fully gone thru and redone. I will post pictures tonight. Dont knock me for my miscolored parts. They were all planned to be red but whatever fits I use. I have cut very few corners but color is just minor for the time being.
I do all my own machining and have access to a personal machine shop for all my custom work.
holmes14
11
Jun 6, 2008 01:08 PM
slowhonduh93
Aug 23, 2007 07:37 AM
Racerboy03
Dec 11, 2004 11:40 PM
