Hard steering.
Old Jul 10, 2013 | 05:26 PM
EgHatchy96's Avatar
Icon2 Hard steering.
When I first got the car, it had no power steering, so I just let it be since it's not too bad since it's such a light car. But, my issue now is that it's got significantly stiffer. When I was dropping the car today, I noticed that my rack boots are almost gone. Just about, & it looks like no lubrication in there anymore. Help please? 93 Civic Hatch CX.
Old Jul 10, 2013 | 07:33 PM
axis11's Avatar
Default Re: Hard steering.
Clean and re-lube the rack. Replace worn boots.
Old Jul 10, 2013 | 09:13 PM
EgHatchy96's Avatar
How do I relube the rack? What do I relube it with?
Old Jul 11, 2013 | 06:45 AM
axis11's Avatar
Turn steering wheel hard right. The left end of the rack will stick out. Clean with solvent and apply a general purpose grease. Do the same on the other side. Also inspect for damage the sliding part of the rack and the teeth. Grease them well and install new boots. Remove rack guide screw, clean and stuff it with grease. Readjust the rack guide so that it is not too tight and not too loose. Search for a"how to" on adjusting the rack guide. Also check your ball joints while you're in there. Is there a binding feeling (un-even resistance) when you turn the wheel lock 2 lock?
Old Jul 11, 2013 | 05:29 PM
EgHatchy96's Avatar
My ball joints are pretty much gone.. I have to get new ones. I wasn't sure that that could affect my steering tho, just really rough feeling suspension
yohimbine
Sep 12, 2013 08:49 PM
B18B EK
Apr 7, 2010 06:38 PM
na4now
Feb 7, 2006 10:46 AM
CivicHB93JDM
Sep 8, 2005 09:00 AM
