difference between 2000 civic EX and SI engine wire harness
I was looking at on majestic Honda and I noticed that they are the same (I chose 2DR EX vs SI)
So what is the part number of the engine wire harness? There are several and I'm not sure.
Thanks.
http://www.hondaautomotiveparts.com/...5=WIRE+HARNESS
Thanks.
Also what is the difference between the 2 door and the 4 door ex engine wire harness?
Thanks.
They are not the same. a 99-00 civic ex will have the small rectangle plug for the distributor. a 99-00 si will have a square plug.
this ^^^^ and the crank sensor plug is 2 wire fir the si and 3 wire for every thing else..
thank you for your help.
99-00 civic ex and 99-00 em1 use the same harness everything is pretty much plug and play but you have to extend 2 sensor wires and the distributor plug might be true cause i have seen something about it being different everything else works you just need a ecu from the si
From: Pensacola, FL and every Court House in Louisiana
Your advice giving card is revoked!!
lol nice ^^^
Anyone has any idea on how to address the 3 wire vs 2 wire crank position sensor issue? I'm putting this gsr/b20 setup in a SI and in my previous setup (in a 96 ek) I didn't have to deal with this problem.
Thanks again.
Thanks again.
You could do the bypass trick. http://technet.ff-squad.com/ckftrick.htm
whyS0serious
13
Jan 12, 2015 06:20 PM
