Hondata headache! Insight much appreciated!
Old Jul 9, 2013 | 02:35 PM
saccord's Avatar
Default Hondata headache! Insight much appreciated!
1999 Honda Cr-v
Built Turbo b20
Hondata s300 on p28 with Zerg industries jumper harness
Here's the deal:
My p28 will not turn the fans on when the A/C is turned on... Only once the temp switch tells the fans to turn on.
I put the stock ecu in, fans turn on when A/C is turned on...
I have checked the jumper harness and the FANC wire converts properly.
Does anyone have any input on the topic?
Old Jul 9, 2013 | 03:36 PM
Spunkster's Avatar
Default Re: Hondata headache! Insight much appreciated!
Try the ECU in a vehicle you know the fan control is working in and see if this ECU works. You can also try a known workign ECU in this vehicle and see if it still works. This will help you determin if is a faulty ECU or a problem with the way this vehicle is wired. This will not be an issue with the the s300 if everything else is working.
Old Jul 13, 2013 | 07:56 PM
VegasInvasion's Avatar
I'm Huge In Japan
Parameters - Protection - Radiator Fan
just override it. if it still doesn't work, the ECU is probably bad or the S300 not installed properly. Or you may have a bad rom, try starting with a different base
XX Boosted Si XX
Sep 16, 2007 02:33 PM
jdmteg33067
Oct 14, 2005 09:23 PM
Lucky_Smurf
Jan 26, 2005 09:10 AM
AgentJam
Mar 17, 2004 05:23 PM
