D16Y7 -> Y8 manifold swap: throttle cable.
Old Jul 8, 2013 | 11:35 PM
Axatax's Avatar
Default D16Y7 -> Y8 manifold swap: throttle cable.
I've read up on several of these swaps on the 'net, and many (actually, all that I have found) of these write-ups claim the Y8 throttle cable is more "responsive" than a Y7 cable. Why is this case? Both the Y7 and Y8 throttle cables on EJ Civics share the exact same part #. What accounts for greater throttle response with same throttle cable?
2K DX throttle cable: 17910-S01-G03
2K EX throttle cable: 17910-S01-G03
Old Jul 8, 2013 | 11:51 PM
jbpnoman's Avatar
Default Re: D16Y7 -> Y8 manifold swap: throttle cable.
It's this great thing called the butt dyno. Also, if they're replacing their old, worn out cable with a new OEM cable, of course it'll have better response. Those cables stretch over time.
Old Jul 9, 2013 | 01:22 AM
ferio-ichi3's Avatar
Ferio Wdm Edition
I have a 2k civic lx with this swap, and i kept my throttle cable because i could not find an ex cable..works perfectly fine lol. I hear the ek ex throttle cables are shorter? I said fudge it, and went along with it! Do it
Old Jul 9, 2013 | 01:23 AM
jbpnoman's Avatar
They aren't shorter. They're the exact same part number.
Old Jul 9, 2013 | 02:22 AM
94EG8's Avatar
Seagull Management
Oh yes they are.
No they're not.
The Y7 has an extra long throttle cable to reach around to the weird straight up throttlebody, Y8 is a more normal length.
Old Jul 9, 2013 | 02:30 AM
jbpnoman's Avatar
Originally Posted by 94EG8
Oh yes they are.
No they're not.
Then can you explain and/or clarify the OP?
From how I look at it under my hood, the Y7 TB sits dead center, whereas the Y8 TB sits further towards the passenger side of the car, which would logically be further away from the grommet hole the cable comes through in the firewall.
Old Jul 9, 2013 | 04:58 AM
kyden's Avatar
your part numbers are wrong.
dx:
17910-S01-G03
ex:
17910-S01-A02
I know both cables are indeed different. I have owned both cars. the dx cable is longer, as it loops around the front of the car.
Old Jul 9, 2013 | 05:47 AM
Ferio Wdm Edition
Dnt the dx ex TC make a nice bend before the arc goes even near the valve cover? I know the dx makes a pretty wide turn..
Old Jul 9, 2013 | 07:53 AM
HondaPartsHero's Avatar
Technical Hero
There is this DIY as well using the DX cable
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-re-route-d16y7-throttle-cable-better-pedal-feel-3010466/
hondadda
Oct 6, 2007 06:49 AM
Wazup
Feb 21, 2006 11:26 AM
dogfood
Jun 1, 2004 02:47 PM
