Highway speed front end shake
Old Jul 8, 2013 | 12:27 PM
hatch92civic's Avatar
Default Highway speed front end shake
Just picked up a 90 civic Si with 156k runs great and smooth around town but once I get on the freeway I get a shake in the front end. No shaking in the steering wheel, I feel it in my seat and feet mostly. Starts above 70mph. The more gas I give it or try to speed up the worse the shake gets. Put a set of hx wheels on and still does the same thing. Any ideas?
Old Jul 10, 2013 | 05:15 PM
Default Re: Highway speed front end shake
Had the wheels and tires rebalanced today but problem is still there. No one can help?
Old Jul 10, 2013 | 05:27 PM
F22Master's Avatar
Axles, wheel bearings, brake rotors, it could be anything rotating.
Old Jul 10, 2013 | 05:32 PM
Tyson's Avatar
Check for play in ball joints.
Also take your rotor off and clean the face of the hub. I fond once the rotor was not cleaned off when new and there was a film of the anti rusting oil from when they come new was that was not cleaned off. So it was causing vibrations and warping my rotors too.
Similar to you since the vibration happens after 60 mph when it's typically just a balance issue.
Old Jul 10, 2013 | 06:30 PM
EFlovin''s Avatar
Could be mounts. They get old and the bushings crack.
Old Jul 10, 2013 | 06:43 PM
jpnolan's Avatar
Also could be a bent wheel.
Old Jul 11, 2013 | 05:52 AM
category5's Avatar
Jack the front end up and place it on jackstands, leave the wheels on the car. Then grab a wheel and check for any play from <> like 9 and 3 oclock and also ^V 12 and 6 oclock.
Any play from 12 and 6 is most likely ball joints
Any play from 9 and 3 is most likely tie rod ends (or the rack end bushing if play is only on pass side)
No play, possibly a balance issue.
Play in all directions possibly wheel bearings.
cdmef
Dec 20, 2008 07:17 AM
civic89si666
26
Feb 7, 2008 10:33 AM
R6E6I6D
Jan 19, 2006 12:43 AM
honda94ex
Aug 14, 2005 10:48 PM
Elmojo
14
Aug 11, 2004 03:43 PM
