AC + Pwr steering in EJ1 b18c swap..HELP!
Old Jul 8, 2013 | 08:14 AM
JosB7's Avatar
Icon6 AC + Pwr steering in EJ1 b18c swap..HELP!
i have a 94 EJ1 with a b18c in it and was wondering if it would be better to take the power steering out due to the fact that I CANNOT FIND a damn p54 del sol bracket for the AC -_-. The car does not have power steering on at the moment but I was planning on putting it back on since it has all the lines and rack+pinion for it. Should I get a new rack and pinion and use a crv bracket for the compressor?! or are the other brackets that would work and allow me to put power steering back in? I also need AC parts if anyone knows of any
Old Jul 8, 2013 | 08:25 AM
kyden's Avatar
Default Re: AC + Pwr steering in EJ1 b18c swap..HELP!
buy the bracket from the dealer?
Old Jul 8, 2013 | 12:50 PM
jimbo slice's Avatar
Several options.. If you have a b-series compressor and bracket have the ac lines modified. On my 96 hatch I am using a 92 integra compressor and bracket. I went to a junk yard and cut the suction and discharge hose ends going into the compressor off of the hoses, then took my original 96 civic hoses ( both suction and discharge ) to an AC repair shop and had them remake the hoses using civic ends on one side Integra ends on the other side going into the compressor.
Or option 2, just order a crv or del sol vtec bracket and reuse the original civic compressor and lines.
I didn't want to wait for the bracket to be orderd and I already had the integra compressor and bracket, so I used what I had. I spent $70 rebuilding the lines and that included new hose.
Old Jul 9, 2013 | 06:41 AM
JosB7's Avatar
Yeah ordering the p54 bracket from the dealership will cost me $230 -_- I need to figure this out because its getting so darn hot outside. Maybe I'll try to find a non stripped Honda at a junk yard around here (very hard to find). Thanks for the input
Old Jul 9, 2013 | 10:29 AM
JosB7's Avatar
...ok wait up. Will a P7J bracket also work!? I know they both do but I want to put Pwr steering in the EG. Will this bracket from the CRV (much easier to find) allow me to have it!?
Thanks in advance
Old Jul 9, 2013 | 10:46 AM
kyden's Avatar
crv bracket does not work with power steering.
buy it off one of the oem parts websites? 120+ shipping from majestic.
Old Jul 9, 2013 | 11:16 AM
JosB7's Avatar
Icon2 Re: AC + Pwr steering in EJ1 b18c swap..HELP!
woah, never knew...sorry I'm a newb I think thats what I will do! I need the pulley also though right?! also..I have a power steering pump from a gsr with a lower bracket only. Do I need an upper bracket?! and will the pump work with the civic lines and rack?!
Thanks a lot
Old Jul 9, 2013 | 03:38 PM
jdmem205's Avatar
Just use the stock pulley from your stock bracket thats what i did
Old Jul 10, 2013 | 05:25 AM
kyden's Avatar
you need a 98-01 integra or 99-00 si pump. You need all the brackets for it (obviously)
Old Jul 10, 2013 | 07:36 AM
JosB7's Avatar
Thanks, I have a GSR pump with AEM pulley and p72 lower bracket. I know I need the upper bracket but is there a difference between 94-97 and 98-01 integras? and can i keep everything else like the hose and reservoir from the EJ civic?
I found a p54 compressor bracket with pulley on here btw, thanks a lot. Honda-tech is the bees' knees, you are all very helpful!
Old Jul 10, 2013 | 08:13 AM
kyden's Avatar
sorry I thought you had a 96-00 for some reason.
you need a 94-97 integra pump. the hose fitting diameter is different.
Old Jul 10, 2013 | 11:34 AM
JosB7's Avatar
Damn it. I got one without knowing this -_- I know its a gsr pump but idk what year...I'm crossing my fingers its a 94-97
Old Jul 15, 2013 | 05:55 AM
USDM EG's Avatar
there is one on ebay, I sent the guy a message asking if it is replicated after the CRV or del sol bracket. awaiting responce.
http://www.ebay.com/itm/AC-Bracket-B-Series-Engine-Swap-Civic-Integra-B16-B18-Air-Compressor-Mount-EG-DC-/230701910748?pt=Motors_Car_Truck_Parts_Accessories&hash=item35b6e7cadc&vxp=mtr
Old Dec 19, 2014 | 09:43 AM
JosB7's Avatar
I'm back to dealing with this -_- the boots on the rack and pinion on my car are all messed up so I think I am going to need to change the whole thing. Which rack and pinion do I need to buy? a 94 ej1 or a 94 gsr? I might as well install the power steering back in the car but I am unsure of the parts I really need.
Bloody Hatch
13
Jul 1, 2012 07:58 AM
r1whore
Sep 10, 2008 01:30 PM
raidacaipo
12
Jul 11, 2008 06:57 PM
D16Z6_turbo
Dec 29, 2004 06:36 PM
endlessdv
Sep 24, 2004 02:13 AM
