98 ek dx with check engine light. HELP
Old Jul 7, 2013 | 11:11 PM
ef_hatchback's Avatar
Default 98 ek dx with check engine light. HELP
Car is a 1998 ek hatchback dx obd2a. It has a y7 motor with y8 manifold. I moved the pin to the correct spot for a 2 wire obd1 iacv. I start the car it idles fine, then when I drive it an stop, it idles at 1500 to 1600 back an forth, small bounce. I've checked the codes an I got an error reading codes. Also when I drive the car an let off the gas pedal an go to press it, pressing it again jerks.
Old Jul 7, 2013 | 11:13 PM
jbpnoman's Avatar
Default Re: 98 ek dx with check engine light. HELP
First off, if it's a DX, it's an EJ6, not an EK.
Check the FAQ's sticky, there's a how-to for manually checking codes. All you need is a paperclip or short length of small gauge wire. Sounds like your IACV wasn't wired correctly, though.
Old Jul 8, 2013 | 01:21 AM
HondaPartsHero's Avatar
Technical Hero
You can't wire 3-2 wire and still use the Y7s ecu. Wire it back and use the Y7 throttle body.
Old Jul 8, 2013 | 08:16 AM
Ok. So resulting in that issue, I either have to use a y7 throttle body convert back to a three wire iacv or stay converted to a two wire iacv and get a obd2a to obd1 jumper harness with a dx ecu??
Old Jul 8, 2013 | 08:20 AM
grumblemarc's Avatar
The Grumpiest
Who said anything about the ECU?
Old Jul 8, 2013 | 08:26 AM
kyden's Avatar
well there's no real good option here. you'll have to use your dx throttle body. I have yet to see a good map for d16y7/8 available yet.
Old Jul 8, 2013 | 08:33 PM
Ok we'll no one said anything about an ecu beside the statement said I can't run a 2-wire plug with my stock dx y7 ecu. I'm gonna put the y7 throttle body on an see if that works. Any other suggestions?
Old Jul 8, 2013 | 09:10 PM
jbpnoman's Avatar
Like I already said, pull the code(s). You can't fix something if you don't know exactly what the problem is in the first place.
Old Jul 9, 2013 | 11:51 PM
I fixed it. Put a y7 throttle body with gasket, changed the throttles out an put it on, no more check engine light an its idles perfect now... Thanks guys.
tablecivic
11
Aug 6, 2017 02:21 PM
youryanyou
Feb 9, 2011 12:43 AM
Rodzknight
17
Feb 27, 2008 09:06 AM
KiNG $h!t
Jan 30, 2005 09:45 PM
