Loose windshield wiper switch
Old Jul 6, 2013 | 10:34 PM
EgHatchy96's Avatar
Default Loose windshield wiper switch
I searched & thought I'd find something cause I've seen this issue pretty commonly around my area, but for some reason around here, a lot of Eg's have the problem where the Windshield Wiper toggle arm/switch on the right side of the steering column is really loose & just basically falls & turns on when you do a really good WOT pull & is very annoying. I was wondering if any of you guys had a simple fix for this, cause it has me stumped.
Old Jul 7, 2013 | 03:28 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Loose windshield wiper arm.
Replace it.
Old Jul 7, 2013 | 04:39 AM
axis11's Avatar
Got mine from the scrap yard for 13$. Something is broken inside the switch. You may open it up, remove the contact points for the single swipe mode. You will loose that particular function but you get rid of the wiper running when you hit wot and potholes. Your choice.
Old Jul 7, 2013 | 12:09 PM
B_Swapped93's Avatar
Default Re: Loose windshield wiper switch
pick n pull. easy and simple to replace.
Mr.Death
28
Jul 13, 2011 02:41 PM
deviant1
Jun 14, 2006 04:39 PM
ferio 95
Mar 3, 2005 04:47 AM
io_burn
14
Feb 25, 2002 05:07 PM
