welding a lever inside the tranny?
Old Jul 5, 2013 | 02:45 PM
RACEPAK's Avatar
Default welding a lever inside the tranny?
hey guys,
i had this y2 transmission sitting for a while, i opened it up and found that the shift ?lever? inside the tranny is cracked, do you guys think its repairable?
i tig, so no problem there, which rod do you recommend i should use?
thanks!
Old Jul 5, 2013 | 03:11 PM
95 modified's Avatar
Default Re: welding a lever inside the tranny?
Not sure were you live but should bring it to a shop that repairs transmissions or transmission exchange. They would know definitely.
Old Jul 5, 2013 | 05:14 PM
1sick4g63's Avatar
Ya it's repairable. V the **** out of it and do a few layers.
What rod. I have no idea. What alloy is it?
Old Jul 5, 2013 | 05:23 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
you need to take it all apart first and clean the **** out of it, I'm not sure how much oil has gotten into the metal as it's been sitting in oil for years,of course oil is inside of the crack, I dont see any way of cleaning it out without taking everything apart, I know once it's apart and cleaned you can carefully wave a torch over the area to burn out any oil you missed, then clean it again, the crack itself is the easy part, it's getting rid of the oil,just like trying to weld on a used valve cover
Old Jul 5, 2013 | 05:34 PM
1sick4g63's Avatar
And tack that bitch in place, that crack is pretty far down so you don't want it to break when you v groove it.
Old Jul 5, 2013 | 06:53 PM
1998GsRIntegra's Avatar
Getting rid of all the oil that has soaked into it will be the worst part. I just recently patched up a moroso road race oil pan via tig of course for a guy and it was annoying as hell. I cleaned the **** out of it and let it soak in acetone over night but that didn't really seem to help. It was like trying to weld right over paint. Shielding gas coverage was getting all messed up from the oil residue in the metal burning off while I was welding it.
Old Jul 5, 2013 | 10:21 PM
redboost10's Avatar
why not buy a new one/used oem one in good condition? or as much as i hate to say it, speedfactory has one that has worked well for some.
Old Jul 6, 2013 | 01:48 AM
RACEPAK's Avatar
thanks guys.
i clean these stuff with my ultrasonic cleaner so no problam there,
wow. that part is expensive!!! anyone know how this whole assambly called?
Old Jul 6, 2013 | 05:10 AM
tepid1's Avatar
It's called a shift change holder assembly. In short SCHA.
Speed factory makes a replacement piece that is much better than the OEM unit.
Old Jul 6, 2013 | 08:05 AM
Find the reason it broke first, as long. As its clean,a good weld will make it good as new
Old Jul 6, 2013 | 01:09 PM
88_hatch_ls's Avatar
I actually broke on completely in half shifting to hard before when I was younger. I took it out and had it welded and it worked perfectly and never happened again! Good luck
Old Jul 6, 2013 | 03:19 PM
It seems to be a common failure point, once its been fixed it shouldbe fine
Old Jul 6, 2013 | 04:35 PM
RACEPAK's Avatar
thanks for the responses guys,
i think it broke because the shift arm is slightly bent, dont know why, i got it this box way back.
Old Jul 11, 2013 | 01:18 PM
K24RWD's Avatar
Hi,
I would clean it , tack it , small V cut and TIG weld it with 312 SS wire. I have used 312 for years for every type of steel and it is the best as far as I'm concerned.
Mark
Old Jul 12, 2013 | 11:37 AM
sidewayz6.6's Avatar
As said, clean it. Heating it up in an oven will help get the oil off, just don't use an oven you plan on cooking in ever again.
Old Jul 12, 2013 | 08:13 PM
kingofbattle909's Avatar
lemme see if I got another. I will let you know!+
*Edit
Pm'ed
Old Jul 13, 2013 | 05:39 PM
pgpbubble's Avatar
I would just find a used one, or buy the speedfactory one as stated.
hybridEj6
Feb 16, 2004 01:27 PM
btleier
Oct 6, 2003 06:18 PM
