Weird Idle... need help.. *VID*
Old Oct 24, 2002 | 11:58 AM
Lost Type R's Avatar
Default Weird Idle... need help.. *VID*
dunno whats wrong with my idle.. but doesent sound normal to me... im thinkin its the tranny... what u guys think?
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D
Old Oct 24, 2002 | 12:09 PM
johnzm's Avatar
Default Re: Weird Idle... need help.. *VID* (Lost Type R)
its gona blow up!!!
Old Oct 24, 2002 | 12:11 PM
Default Re: Weird Idle... need help.. *VID* (johnzm)
its gona blow up!!!
ur not serious are you
Old Oct 24, 2002 | 12:15 PM
CWBETB's Avatar
Hmmm hampster stuck in the intake?
Old Oct 24, 2002 | 12:17 PM
Default Re: Weird Idle... need help.. *VID* (CWBETB)
I dont think it could be just that... either that.. i woulda noticed it..
Old Oct 24, 2002 | 12:35 PM
raene's Avatar
First thing I'd do is pull your valvecover and check the timing belt & rocker arms, etc. Also, I'd pick up an oil pressure gauge and check for oil pressure.
Old Oct 24, 2002 | 05:35 PM
liam821's Avatar
25 Year Member
Im guessing..only guessing of course...i bet its either the timing tensoner, water pump, oil pump, or the timing belt is too tight. Thats my guess.
Its not rod bearings...that sounds like clank clank clank.
liam
Old Oct 24, 2002 | 07:17 PM
USDM 4G VTEC's Avatar
u supposed to put 92 octane or higher on that,not diesel!
anyways that for me sounds that u need valve adjustments, then u need to check if u get oil pressure bc that sounds like the head isnt getting that much oil... also check for the T belt tensioner like the guy before me said... after that check regular alternator belt.. make sure the alternator bearing isnt bad...other than that, just pray is not the rod bearings....
Old Oct 24, 2002 | 07:31 PM
xtrafastcivic's Avatar
Default Re: Weird Idle... need help.. *VID* (JDM EF9)
if it's not the vavles or t belt it's your main bearings...
Old Oct 24, 2002 | 08:39 PM
Default Re: Weird Idle... need help.. *VID* (XtraFastCRX)
AH!!! what the hell is it?!?! rod bearings.. alternator belt... the tranny.. my valves... bleh~! ill jus take it in to an acura/honda specialist...
Luward
Aug 16, 2013 08:23 PM
Meraut
May 8, 2013 09:43 AM
turbotime
May 19, 2006 09:22 PM
llevity
Jul 12, 2005 02:39 PM
gooberwolf
Aug 6, 2003 01:59 PM
